w580 insert correct smartchip problem already it work in airtel sim card it problem was hanging so i flash it ok but i use airtel simcard soing in display insert correct smartchip what to do this problem see this flash id v0.915056/UNI Loaded 51 flash descriptors CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:3525600 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):W580i MAPP CXC article: R7AC001 prgCXC1123480_CINGULAR_LA MAPP CXC version: R7AC001 Language Package: CINGULAR CDA article: CDA102774/102 CDA version: R17A Default article: cxc1123364 Default version: R7AC001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R7AC001_CXC1123480_CINGULAR_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 48 secs. SIGNED MODE (USING SERVER) CFG:100111000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3525600 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "C:\Documents and Settings\kDesktop\R7AC001_1123480_CINGULAR_LA.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "C:\Documents and Settings\\Desktop\R7AC001_FS_CINGULAR_LA_RED_CID52 .ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 2660 Will flash 133 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed USERCODE RESET TO "0000" using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 542 secs. |
any one see this .................................................. ................. |
any one see this .................................................. ................. any solution |
you have to unlock the phone using either CRUISER, SETOOL OR DREAM BOX if you have any of them , indicate then i will give u the procedure best regard michael |
