Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-30-2009, 11:14   #1 (permalink)
ka jagan's Avatar
Member: 645764
Thanks Meter: 207
w580 insert correct smartchip problem
already it work in airtel sim card it problem was hanging so i flash it ok but i use airtel simcard soing in display insert correct smartchip what to do this problem
see this flash id
v0.915056/UNI
Loaded 51 flash descriptors
CFG:000000000000
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0052
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:3525600 CERT:RED
FLASH CID:52 COLOR:RED
Model (from GDFS):W580i
MAPP CXC article: R7AC001 prgCXC1123480_CINGULAR_LA
MAPP CXC version: R7AC001
Language Package: CINGULAR
CDA article: CDA102774/102
CDA version: R17A
Default article: cxc1123364
Default version: R7AC001
PROVIDER: MULTIPLE
Network LOCKED
RESTORATION FILE NOT PRESENT
"R7AC001_CXC1123480_CINGULAR_LA"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
SECURITY UNITS BACKUP CREATED.
Elapsed: 48 secs.
SIGNED MODE (USING SERVER)
CFG:100111000000
FLASH CID: 0052
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID:897E
writing "C:\Documents and Settings\kDesktop\R7AC001_1123480_CINGULAR_LA.ssw"
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "C:\Documents and Settings\\Desktop\R7AC001_FS_CINGULAR_LA_RED_CID52 .ssw"
SSW uses full hash, hash len is: 2660
Will flash 133 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
USERCODE RESET TO "0000"
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 542 secs.
The Following User Says Thank You to ka jagan For This Useful Post:
Old 11-30-2009, 15:00   #2 (permalink)
ka jagan's Avatar
Member: 645764
Thanks Meter: 207
any one see this .................................................. .................
Old 12-01-2009, 05:05   #3 (permalink)
ka jagan's Avatar
Member: 645764
Thanks Meter: 207
any one see this .................................................. ................. any solution
Old 12-03-2009, 05:40   #4 (permalink)
ka jagan's Avatar
Member: 645764
Thanks Meter: 207
Old 12-04-2009, 09:56   #5 (permalink)
Member: 782390
Sonork: oshiu
Thanks Meter: 55
you have to unlock the phone using either CRUISER, SETOOL OR DREAM BOX if you have any of them , indicate then i will give u the procedure
best regard
michael
w580 insert correct sim problem maheshsaiganesh SETool2 7 03-17-2010 11:23
insert correct card problem a 1018 s freakyass Old Ericsson Phones & Sony Phones 15 12-28-2005 10:51
insert correct word problem jaaja Old Ericsson Phones & Sony Phones 2 03-06-2005 21:05
Se T100 Insert Correct Sim Problem abbeydguru Sony Ericsson 2 11-25-2004 11:31
Insert correct card problem please help..... uwenk98 Old Ericsson Phones & Sony Phones 2 01-15-2003 08:24
Page generated in 0.23508 seconds with 8 queries
