Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 07-11-2008, 11:43   #1 (permalink)
Member: 543544
Thanks Meter: 36
w580 no display
set no drop or water damage , but no display !! already try to chg it all the ribbon insite the phone & the lcd too , still the same !! any more solution ? thanks ..
The Following User Says Thank You to joecheun For This Useful Post:
Old 07-15-2008, 12:45   #2 (permalink)
Member: 543544
Thanks Meter: 36
help !! anymore solution ......
Old 07-16-2008, 10:44   #3 (permalink)
Member: 157053
Sonork: 100.1606219
Thanks Meter: 489
you should change n1800 or other parts about light
for more help click on thanks.
The Following 12 Users Say Thank You to morteza-icu For This Useful Post:
Old 07-23-2008, 15:53   #4 (permalink)
Member: 805902
Thanks Meter: 31
here 2 strips [ribon] or in w580 change both ur problem vil be solved..
Old 07-26-2008, 01:31   #5 (permalink)
Member: 125632
Thanks Meter: 229
Talking
i come accross 2 or 3 like this,,it seems to be where the lcd connects to the top keypad flex,there is longer connector (right next to it),main flex from the 2 halfs connects onto this,make sure this is connected sercurly,as pulling this1 apart,usually breaks connector on 1 or 2 pins,very slightly,similer prob with w850i top keypad,but not as bad......lol.....
anyway this easy to test,just pull front fasia off,carefully prise lcd away,without disconnecting,
power on mob,while pressing dwn on the long connecter.
a reflow worked for 1 mob,but new top keypad flex for the other.
on same subject,,i ava w580i,powered on great,then when screen went to standby,slide up slider,lcd lights up but the lcd just appear light blue from then on,,,try another lcd and working,but there must be some dodgy lcd for these mobs about for screen just 2 go blue like that,if i put the the faulty lcd on another mob,,still same,,light blue screen,,,phone all working in background,,,,
hope this helps some of you out
The Following 2 Users Say Thank You to bcatlock1 For This Useful Post:
Old 11-17-2008, 10:06   #6 (permalink)
Member: 30630
Hello,
I tried to replace n1800, lcd, both the strips(ribbons) but problem didnt got solved, is there any other spare that will make handset good.
Thanks & Regards.
Old 04-24-2010, 14:08   #7 (permalink)
Member: 923809
Sonork: don't what is sonork
Thanks Meter: 3
Try this may help u
Originally Posted by azizraza View Post
Hello,
Thanks & Regards.
Try this may help u...
Old 07-13-2010, 06:54   #8 (permalink)
Member: 477355
Thanks Meter: 19
Try what brother,plz clear
Old 07-30-2010, 18:53   #9 (permalink)
Member: 682331
Thanks Meter: 2
It checks this please
The Following User Says Thank You to tecnibros For This Useful Post:
Old 07-31-2010, 15:54   #10 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 919
try this solution,,,,,,,,,,,,,RapidShare: 1-CLICK Web hosting - Easy Filehosting
V3 no display,no display light celluniversal Motorola P2k 21 11-21-2011 05:57
w580 blue display b12345 Sony Ericsson Hardware Repair 1 08-05-2010 20:30
w580 screen display problem after flashing sonetek SETool2 0 12-02-2009 08:47
w580 / s500 display problem brynbryn Sony Ericsson Hardware Repair 7 11-21-2009 17:58
w580 no display sandy629610 Sony Ericsson Hardware Repair 2 03-26-2009 10:14
Page generated in 0.32089 seconds with 8 queries
