Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-18-2009, 17:03 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1127498 Status: Offline Thanks Meter: 10 | Sony Ericsson K810i Joystick Repair Looking for some advice about repairing the joystick on a Sony Ericsson K810i. Someone has already tried to repair the phone by soldering on a new joystick, but when powered up, the joystick still didn't work. I've un-soldered the joystick and I can see that a few of the pads have been lifted off the PCB, and some of the nearby components (diodes?) have been destroyed or removed. (Click image for larger version) I've found a few diagrams which appear to suggest how to re-wire the joystick when the pads are missing, but they are not all the same. Diagram #1 is, I think, from a K790 although it does mention K800, but the layout is slightly different. Regardless, it suggests removing the diodes and connecting to the pads as follows: 5, 4, 3, 2, 1 (Click image for larger version) Diagram#2 leaves the diodes in place and connects from them to the pads as follows: 5, 1, 3, 2, 4 (Click image for larger version) Digram#3 suggests removing the diodes and connecting to the pads as follows: 5, 1, 3, 2, 4 (Click image for larger version) So, which one is right? Also, on my PCB some of the joystick pads are still there so should I use them and only use the alternative wiring for the missing ones? Or is it best to use the alternative wiring for all of the joystick points? Help appreciated, thanks |
The Following 10 Users Say Thank You to Shooog For This Useful Post: |
11-18-2009, 17:35 | #2 (permalink) |
Member: 1127498 Status: Offline Thanks Meter: 10 | Just looked at diagram#1 again and I'm wrong. It is wired in the same order as the other ones. But I'm still unsure what to do about missing diodes? and whether to only use the alternative wiring for the missing joystick pads or for all of the joystick points? Thanks |
unlock code for sony ericsson k810i | swinbank5 | Phone Unlocking Codes & Maps | 2 | 02-25-2010 08:39 |
sony ericsson K810i user code failed | mohit_kripalu01 | SETool2 | 5 | 02-24-2010 13:59 |
SONY ERICSSON K810i | ddumaguin | Sony Ericsson Hardware Repair | 2 | 02-03-2009 05:25 |
Mail application for Sony Ericsson K810i | Mobilemania250 | Sony Ericsson Media, RingTones, Games | 0 | 07-01-2007 15:43 |
