w580 / s500 display problem how do we check the difference of w580 and s500 by the look of it's board??? cause there's a model which i change the flash and flash it with w580 file. everything is ok except that the screen will go blank after a while but if i press any key the display will be normal again and then blank again. any help or suggestion?? i've changed lcd/ ribbon, mmc holder ribbon. are there any lcd ic?? |
On board is also the difference is quite large, the s500 has several components missing on w580 and all spaces are filled. |
same problem in w580i blue display bounjer flex . slidderribbon and display already change .software done but blue display problem not solved |
1 Attachment(s) Quote:
hello dear, rehot these ic,s ....otherwise change it...i hope ur problam will solve |
How change without damage the D2000 ? :S |
Have sama problem but i tried the above solution but was not successful. Any other idea? |
hallow dear you can check the belt or jack in the board i think you will solve the problem |
try to replace flash IC , re-write data ... |
