Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 09-10-2009, 11:09   #1 (permalink)
Member: 889182
Thanks Meter: 3
w580 / s500 display problem
how do we check the difference of w580 and s500 by the look of it's board???
cause there's a model which i change the flash and flash it with w580 file. everything is ok except that the screen will go blank after a while but if i press any key the display will be normal again and then blank again. any help or suggestion?? i've changed lcd/ ribbon, mmc holder ribbon. are there any lcd ic??
Old 09-10-2009, 18:04   #2 (permalink)
Member: 817867
The biggest difference is housing him in the S500 buttons which is the turn of the directional button are all separated and the w580 are together ...
On board is also the difference is quite large, the s500 has several components missing on w580 and all spaces are filled.
Old 09-11-2009, 08:22   #3 (permalink)
Member: 126771
Thanks Meter: 20
same problem in w580i blue display bounjer flex . slidderribbon and display already change .software done but blue display problem not solved
Old 09-11-2009, 22:01   #4 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
hello dear,
rehot these ic,s ....otherwise change it...i hope ur problam will solve
The Following 4 Users Say Thank You to chohansahib For This Useful Post:
Old 10-03-2009, 17:23   #5 (permalink)
Member: 979538
How change without damage the D2000 ? :S
Old 11-15-2009, 11:26   #6 (permalink)
Member: 153875
Thanks Meter: 31
Have sama problem but i tried the above solution but was not successful. Any other idea?
Old 11-21-2009, 07:59   #7 (permalink)
Crazy Poster
Member: 679472
Thanks Meter: 6
hallow dear you can check the belt or jack in the board i think you will solve the problem
Old 11-21-2009, 18:58   #8 (permalink)
Member: 229358
Thanks Meter: 5
try to replace flash IC , re-write data ...
w580 screen display problem after flashing sonetek SETool2 0 12-02-2009 09:47
sony ericson w580 display problem kanewilliam Sony Ericsson Hardware Repair 0 06-08-2009 04:33
SonyEricsson W660 | W580 | S500 SUPPORTED WotanServer.com WotanServer 2 04-14-2009 17:08
display problem after flashing w580 gsmservices SETool2 4 01-05-2009 13:28
S500 Lcd Problem display is dissappear osmani Samsung Flashers, Software, Firmware. 0 01-14-2006 13:13
Page generated in 0.32494 seconds with 9 queries
