Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-07-2008, 15:20   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question W880 -headset mode+charging ???
I have a SonyEricsson W880 wather damaged that has 2 problems:
-simulates charging (when I put the garger it says:unknown battery and it starts showing that is charging but the battery doesen't charge-it has the same voltage as before after hours of charging)
-on the screen I can see the handsfree and I cannot hear anything because of that)
I had cleaned the intrire pcb and heated with low temeratre but the same...
Is there anyone that has any ideea of what is wrong(the battery is ok)???
Old 11-10-2008, 00:02   #2 (permalink)
fonekrazy's Avatar
Member: 884199
Thanks Meter: 65
Problem lies in the charging block try replacing the block.
Old 11-10-2008, 07:38   #3 (permalink)
DIGI*TEL's Avatar
Member: 414614
Thanks Meter: 217
reheat or change power ic
Old 11-11-2008, 12:19   #4 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Can anyone pls upload any picture?
Old 12-11-2008, 06:43   #5 (permalink)
Member: 901112
Sonork: 9843790487
w880i mic is not working pls heip
Old 12-13-2008, 05:59   #6 (permalink)
Registered User
Member: 474045
Thanks Meter: 9
w 880 usb mode solution.
1.charging & headset connector right side two leg short it
2.charging & headset ic replace
Old 01-04-2010, 05:32   #7 (permalink)
Member: 1003521
Sonork: saymepro9016
Thanks Meter: 4
whice 1 is headset ic ??any 1 can post pic ??ungent
Old 01-04-2010, 06:04   #8 (permalink)
Registered User
javed ahmad's Avatar
Member: 413478
Thanks Meter: 32
chang haedset ic.........
Old 08-23-2010, 18:16   #9 (permalink)
Member: 281239
Thanks Meter: 18
behind mic got 2 risister 1 is ground 1 is positif....do jumper go to mic.....100 % tested
Old 06-08-2013, 14:16   #10 (permalink)
Member: 1726210
Thanks Meter: 25
Old 06-12-2013, 08:36   #11 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Check Track And Put In Mic Orignal Samsang fones
w880 handfree mode chand_gee Sony Ericsson Hardware Repair 1 10-22-2009 20:47
auto charging and headset mode saifali Infinity-Box 0 03-14-2009 11:09
w880 never complete charging Nadeem97 Sony Ericsson Hardware Repair 0 10-13-2008 17:31
8210 headset mode hightechsquare Nokia Hardware & Hardware Repair 4 08-17-2003 14:35
Headset mode after charging rrundle Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-08-2003 19:33
Page generated in 0.23710 seconds with 10 queries
