Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 07-16-2009, 11:48   #1 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 153
w595 serious error stop charging
water damaged set i cleaned it fully
but it says "serious error stop charging" upon inserting charger
solution please
Old 12-03-2009, 07:17   #2 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
i have same problem help plz................
Old 12-03-2009, 07:23   #3 (permalink)
Crazy Poster
Member: 435341
Thanks Meter: 13
change ur battery
The Following User Says Thank You to sajii For This Useful Post:
Old 12-07-2009, 02:18   #4 (permalink)
Member: 543371
Thanks Meter: 2
up date sw is ok 100%
Old 12-18-2009, 06:51   #5 (permalink)
Member: 711270
Thanks Meter: 30
run with others version sftwares try~~i try c902 b4...after flash with others version...i wrked fine~
Old 12-18-2009, 07:23   #6 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
cheng the orginal battry work fine i check 2 phons.........................................
Old 12-18-2009, 20:12   #7 (permalink)
Crazy Poster
Member: 685120
Thanks Meter: 41
first update yours phone S/W 99% it will solved i have solved this to many time
if not solve so change charging IC
Old 12-19-2009, 12:07   #8 (permalink)
Crazy Poster
Member: 585212
Thanks Meter: 12
i think same mr mfaza idea.
The Following User Says Thank You to datsony For This Useful Post:
Old 12-22-2009, 12:04   #9 (permalink)
Member: 25852
Thanks Meter: 31
ladns any info about wheres IC located
im guessing its the one near connector , but would like to be sure before changing .
Old 04-02-2010, 17:51   #10 (permalink)
Member: 863169
Thanks Meter: 34
i oso need this solution...help
Old 04-18-2010, 17:53   #11 (permalink)
Member: 1030416
Sonork: rinku_2k9
Thanks Meter: 17
change battary connector 100% solution i m tested
Old 04-18-2010, 18:47   #12 (permalink)
Member: 905846
Thanks Meter: 26
Dear Sir.
First of all like others suggested check your battery and level 1-2 trouble shooting.
I strongly recommend you to check if there is a short circuit (Check with multi-meter) between the two points that I have encircled in the picture.
If the two points are not shortened, then place a jumper between them.
The points are located near the camera connector on front side of the board.
Also check if there's is a connection between the board and middle pin in battery connector.
This is a common fault in W595, that connected to identification of the battery.
I also recommend you to check if the phone communicates with PC (Personal Computer) via data cable.
If it doesn't check underneath this small shield (that I encircled in red), that located near the extension card connector in the back side of the board.
It's contains two critical components; The first is responsible for USB<->TM&M conversion and the other is Over-voltage USB protector. So if there is a corrosion in it, there will not be any charge or communication with the PC .
If those two advices didn't helped you, I recommend you to check this component and it's surroundings:
It's a FET transistor that by him the N2000 (analog processor) controls that charging process.
If neither of those solutions didn't helped you then the problem is coming from N2000 and it's located under SE-glue and you can't even reheat him.
Good Luck and Godspeed!
Pavel A.
The Following 3 Users Say Thank You to Hells_Angel443 For This Useful Post:
Old 04-18-2010, 19:46   #13 (permalink)
Member: 505752
Sonork: 1611502:zubair
Thanks Meter: 33
write gdfs fone works 100%
Old 04-21-2010, 09:03   #14 (permalink)
Member: 1193470
Thanks Meter: 2
help
Originally Posted by Hells_Angel443 View Post
Dear Sir.
Pavel A.
You can fly a schematic diagram to me?
Old 04-21-2010, 09:07   #15 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
NOT hardware!
SOFTWARE Problem, UPDATE it to SEUS! Sony Ericsson Update Service
Serious error. Stop charging. Stop using your phone. Call sonyericsson call center sammiebaby_03 Sony Ericsson 17 04-26-2013 11:36
sony ericsson T700"serious error .stop charging .stop using your phone and contact ameerali19 Sony Ericsson Hardware Repair 4 08-05-2012 16:24
K610i Serious Error,stop charging,stop tornado2008 Sony Ericsson Hardware Repair 9 02-13-2011 12:32
SOLUTION !!k550i serious error, stop charging,stop using ur phone contact callcenter harryscelclinic Sony Ericsson Hardware Repair 19 06-15-2010 13:18
Serious error. Stop Charging........ etc etc Phantom Sony Ericsson Hardware Repair 2 11-28-2006 11:52
Page generated in 0.48759 seconds with 8 queries
