Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-26-2009, 20:28   #1 (permalink)
Member: 406728
Thanks Meter: 14
w880 blank lcd
hi
ive got w880 with black lcd(no display) afret powering on phone. phone was cleaned with IPA and flashed with setool. also lcd was changed. where are LCD ICs? photo plz.
Old 03-26-2009, 20:55   #2 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
There is no ic, but a multi resistor just close to the lcd connector
Short it's 4 legs verry easy and enjoy your pics again
On the other side of the board there is a water sticker to remove to access to two others
Max_B
Old 03-26-2009, 21:11   #3 (permalink)
Member: 406728
Thanks Meter: 14
you mean that?
HERE IS SOLUTION
Old 03-26-2009, 22:40   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Yes the one between two connectors is for lcd !
The two of the other side, I'm not sure but you can still Jump or resolder it.
Max_B
The Following User Says Thank You to Max_B For This Useful Post:
Old 03-26-2009, 23:05   #5 (permalink)
Member: 406728
Thanks Meter: 14
for mine replacing that one from the other side (the left one) helped and phone is working now
Old 03-26-2009, 23:06   #6 (permalink)
Member: 266986
Thanks Meter: 5
Br0k3R_PL
yes, exactly
100% good solution
Old 03-26-2009, 23:06   #7 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Shorting each points from side to side with thin wire oughtta do
Max_B
Old 06-27-2009, 22:35   #8 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question
Originally Posted by Br0k3R_PL View Post
you mean that?
HERE IS SOLUTION
this photos are no longer available can someone upload them again I need to repair my phone and I not sure which rezistors I have to short/change...
Old 06-30-2009, 01:14   #9 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
the one across to the lcd connector (8 pins)
Max_B
Old 06-30-2009, 02:54   #10 (permalink)
Vichka Kham's Avatar
Member: 959779
Sonork: 100.1604117
Thanks Meter: 80
Why
Why member in this is very fun
Old 09-09-2009, 10:41   #11 (permalink)
Member: 449479
Thanks Meter: 19
where is the pic man plz up load again
Old 10-06-2009, 18:27   #12 (permalink)
edcentec's Avatar
Member: 232960
Thanks Meter: 419
Here you go....
br
The Following 10 Users Say Thank You to edcentec For This Useful Post:
Old 12-03-2009, 21:55   #13 (permalink)
Member: 1175512
jumped the filers
everything is working
thank you
Old 12-05-2009, 10:02   #14 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
yes this is riht solutions
Old 02-08-2010, 03:15   #15 (permalink)
Member: 169220
is solve my problem....
thanks alot....
W880 blank lcd luyanda Sony Ericsson 0 01-23-2009 05:33
w880 black lcd weird problem TRABEL Sony Ericsson Hardware Repair 3 11-09-2008 17:17
j300 blank lcd, and lcd is good johnny_liang SonyEricsson (USB-Smart) 1 05-10-2006 19:20
8210 blank LCD with good LCD and new uwenk98 Nokia Hardware & Hardware Repair 5 03-19-2004 23:01
G450 BLANK LCD AFTER FLASHING nokya Panasonic 3 07-29-2001 20:24
Page generated in 0.23903 seconds with 10 queries
