Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 09-05-2012, 15:18   #1 (permalink)
Crazy Poster
Member: 890066
Thanks Meter: 22
xperia arc lt15 charg problem
Xperia Arc is a full battery use .Shows an empty battery
I turn on the phone.Charge your mobile display And off
Stay on the phone with USB cable
Charge sign indicating
But it does not charge
I tested the charger and battery
I flash the phone
please help me!
Old 09-05-2012, 15:53   #2 (permalink)
Member: 1639857
Ckeck battery way & charger way ...
The Following User Says Thank You to SOIL2020 For This Useful Post:
Old 09-06-2012, 09:52   #3 (permalink)
Crazy Poster
Member: 890066
Thanks Meter: 22
not work
Did anyone encounter this problem?
Old 09-22-2012, 12:10   #4 (permalink)
A-H-T's Avatar
Member: 36394
Thanks Meter: 250
i did face the same problem after flashing
i already tried many flash files from support 2.3.2 and finally 4.0.4 but still the same result
wbr
Old 09-30-2012, 11:51   #5 (permalink)
Member: 1384596
Thanks Meter: 2
read..
I flash the phone
please help me!
i think there is some issue wid c.c
after check dat section u hv to check battery VBAt area..
Old 01-10-2013, 12:47   #6 (permalink)
Member: 18966
Thanks Meter: 59
hi
solution posted by Zabado*GSM in gem-flash forum
1-unlock ur bootloader from here (Are you really sure? | Sony Xperia)
2- download ZeroPercentFixTool (ZeroPercentFixTool.rar)
3- download fastboot driver (fastboot_with_Android_USB_file.rar)
4- open zeropercentfixtool write the unlock code bootloader for ur phone given from the
site sonymobile in first step
5- press menu key in ur mobile and use the driver from step 3
6- press fix it in zeropercentfixtool
all done
thanks for the man who posted and developed
best regards
Old 06-12-2013, 10:15   #7 (permalink)
Member: 325792
Thanks Meter: 4
Originally Posted by asmar View Post
hi
all done
best regards
thaaaaaaaaaaaanks its work
Old 06-21-2013, 11:56   #8 (permalink)
!!!_babu_!!!'s Avatar
Member: 1627323
Sonork: WhatsApp+8801763009154
Thanks Meter: 481
I am face the same problem its hardware or software problem please tell me............
Old 06-21-2013, 12:46   #9 (permalink)
Member: 18966
Thanks Meter: 59
test this solution posted above for me work many time and it is a soft problem for me at least
br
Old 07-03-2013, 19:10   #10 (permalink)
bsl_bappy's Avatar
Member: 1686868
Sonork: 100.1625990
Thanks Meter: 85
Thumbs up xperia arc lt15 charg problem
It have 25 pin cristal ic same e10i replace it. no jumper solution.
Old 12-04-2013, 22:18   #11 (permalink)
Member: 1706828
Sonork: Milos Klac
Thnx
hi
all done
best regards
THANK YOU MUCH!!! i flashed 10 roms, this helped
Old 12-23-2013, 18:26   #12 (permalink)
Member: 418143
Thanks Meter: 2
S1boot driver problem
i cant install S1boot driver on windows 7 64bits
how i can do that ?
Page generated in 0.27120 seconds with 8 queries
