Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-31-2014, 11:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Portugal Age: 41
Member: 111292 Status: Offline Thanks Meter: 66 | Xperia Miro ST23i Touch Problem Witch had a minor crack, but it still worked fine. I replaced it with a new touch screen but it does not work at all, i tought it might be the new touch faulty. I put again the old touch, until i get a new one, but noticed the old touch does not work at all... I allready updated software but nothing changes... I would be much appreciated if someone could advise, if you allready had a similar problem with this phone. I think it could be some assembly problem, but everything seems fine... Thanks in advance. starxman. |
02-26-2014, 13:45 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK
Member: 232050 Status: Offline Thanks Meter: 23 | I'm having same trouble. I have tried 2 different digitizers but none respond. Old digitizer which did work even though it had a crack in it doesn't work now either. any ideas? |
03-25-2014, 11:38 | #4 (permalink) |
Member: 111292 Status: Offline Thanks Meter: 66 | Hi everyone. I solved the problem, by changing the complete module. I bought a new complete front panel, witch included the touch screen and the lcd allready assembled. And everything went fine. But its more expensive... |
03-25-2014, 12:32 | #5 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | problem is digitizer some digitizer not work with genuine lcd..i have found problem changed diff digitizer then work.. none genuine lcd work with none genuine digitizer..so buy it genuine digitizer then work with genuine lcd..many time tested!! |
04-03-2014, 10:33 | #6 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
i sloved this problem i change lcd, its lcd & touchpad connection or lcd strip cut problem | |
12-14-2014, 00:35 | #7 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1921245 Status: Offline Thanks Meter: 43 | yes indeed this is the problem. this same problem is also at xperia go and tipo i think. You either have to get an original touch screen or a non original touch with non original lcd... tested many many times |
