Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-22-2016, 17:16 | #1 (permalink) |
Banned Join Date: May 2006 Location: france
Member: 270730 Status: Offline Thanks Meter: 67 | xperia vibrat but no work I try with the bottom volume but nothing is there a solution? |
12-23-2016, 15:07 | #2 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | please whats solution When I turn on the phone it vibrates 3 times but it does not turn on i press volume down button plug usb not working this is result sony mobile flasher: 23/046/2016 11:46:07 - INFO - For 2011 devices line, be sure you are not in MTP mode 23/046/2016 11:46:20 - INFO - Device disconnected 23/046/2016 11:46:25 - INFO - Device connected with USB debugging off 23/046/2016 11:46:25 - INFO - For 2011 devices line, be sure you are not in MTP mode 23/046/2016 11:46:38 - INFO - Device disconnected 23/046/2016 11:46:43 - INFO - Device connected with USB debugging off 23/046/2016 11:46:43 - INFO - For 2011 devices line, be sure you are not in MTP mode 23/046/2016 11:46:57 - INFO - Device disconnected 23/047/2016 11:47:28 - INFO - Device connected in flash mode 23/047/2016 11:47:28 - INFO - Device disconnected 23/047/2016 11:47:29 - INFO - Device connected with USB debugging off 23/047/2016 11:47:29 - INFO - For 2011 devices line, be sure you are not in MTP mode 23/047/2016 11:47:36 - INFO - Device disconnected 23/047/2016 11:47:41 - INFO - Device connected with USB debugging off 23/047/2016 11:47:41 - INFO - For 2011 devices line, be sure you are not in MTP mode 23/047/2016 11:47:42 - INFO - Device disconnected 23/005/2016 15:05:40 - INFO - List of connected devices (Device Id) : 23/005/2016 15:05:40 - INFO - List of ADB devices : 23/005/2016 15:05:41 - INFO - - none 23/005/2016 15:05:41 - INFO - List of fastboot devices : 23/005/2016 15:05:41 - INFO - - none 23/005/2016 15:05:50 - INFO - Downloading latest XperiFirm 23/006/2016 15:06:01 - INFO - Please connect your device into flashmode. |
