Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 01-08-2013, 14:06   #1 (permalink)
msa
Member: 17424
Xperia X10 mic problem
Hi
I have Xperia X10 which was water damaged and been repaired ok. All works fine except mic. I have replaced the microphone with a new one but it still dose not work. Is there any solution for the problem ? may be jumpers?
Thanks for the help.
msa
Old 01-09-2013, 00:43   #2 (permalink)
Member: 1573913
Sonork: hardware illustration
Originally Posted by msa View Post
Hi
msa
sony xperia x10 mic modification
try to replace the mic with two legs
positipnya lines add a resistor with a value of 1.2k or 2.2k
see the picture below
dont forget to click thank
Old 01-09-2013, 11:13   #3 (permalink)
msa
Member: 17424
Thanks for the reply
Not sure how to put jumper or resistor on contacts when they are under the microphone? Is there any other place i can connect the resistor & jumper?
Thanks for your time.
br
msa
Old 01-17-2013, 16:55   #4 (permalink)
msa
Member: 17424
Any one have any other suggestions please?
thanks
msa
Old 01-23-2013, 13:27   #5 (permalink)
Member: 1788939
Sonork: 100.1625853
sony ericsson x10 mic solution 100% tested ok
br.
indergsm
The Following User Says Thank You to indergsm For This Useful Post:
Old 01-23-2013, 16:45   #6 (permalink)
msa
Member: 17424
@indergsm
Thanks for the picture. Any idea where I take 2.2k resitor from? (any other board? ) The mic does work when I put jumpers straight across but I get interferance due to no resitor. I have normal large 2.2k resitor but it is to big a size to fit in a small space. Any help to find the resistor will be very much appreciated.
Thanks
msa
Old 02-15-2013, 14:38   #7 (permalink)
Member: 1788939
Sonork: 100.1625853
Here is 2.2K Resistor
BR,
Inder
Page generated in 0.27275 seconds with 11 queries
