Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-27-2013, 17:25 | #1 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1881172 Status: Offline Thanks Meter: 0 | XPERIA X10i green blink and vibration, wouldnt boot *when connected to charger with battery, green LED urns on * when connected to charger without battery, same thing, green led turns on *when i press the power button, green LED blinks one time followed by a vibration, then nothing * when i try to flash it using SEUS and PC companion, it doesnt detect the phone, * when i press the back button and connect USB, it goes to flashmode and it says on the computer: "SEMC Flash device" * with S1tool, when i click identify, here is the log : Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW can't get S1 command header MALFORMED VERSION RESPONSE Elapsed:40 secs. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW can't get S1 command header MALFORMED VERSION RESPONSE Elapsed:39 secs. * when i try to flash it using flashtool, here is the log: 27/018/2013 17:18:38 - INFO - <- This level is successfully initialized 27/018/2013 17:18:38 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00 27/018/2013 17:18:45 - INFO - Device disconnected 27/018/2013 17:18:47 - INFO - Selected X10i / 3.0.1.G.0.75 / GLOBAL-GGL GENERIC 1232-9897 27/018/2013 17:18:47 - INFO - Preparing files for flashing 27/019/2013 17:19:02 - INFO - Please connect your device into flashmode. 27/019/2013 17:19:07 - INFO - Device connected in flash mode 27/019/2013 17:19:08 - INFO - Opening device for R/W 27/019/2013 17:19:10 - INFO - Reading device information 27/019/2013 17:19:10 - INFO - Phone ready for flashmode operations. 27/019/2013 17:19:10 - INFO - Start Flashing 27/019/2013 17:19:10 - INFO - Processing loader 27/019/2013 17:19:10 - INFO - Checking header and it stays there forever, the green bar doesnt move anymore * i took it to repair and the repair guy told me the he tried with SETool Box and failed, i think RIFF Failed too, i dnt kjnow the history of the phone but i can see the JTag marks on the motherboard , im not sure about the RIFF and the SETool box since the technicians where im from are not very good at what they do any help will be appreciated, i have given you all i have done, i am open to any suggestions, anythg, im willng to put the PCB in the oven thank you in advance |
