Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-15-2014, 12:08 | #1 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2098114 Status: Offline Thanks Meter: 5 | Xperia Z L36 network problem i changed complete screen to my xperia z and now when i insert sim card the phone don't find operator signal..i had same problem with wifi signal but wan only bad contact after riassebly...what are gsm antenna signal?? maybe only some bad contacts..please help me |
01-16-2014, 14:43 | #2 (permalink) |
Member: 2098114 Status: Offline Thanks Meter: 5 | Finally i found the problem...is the bottom antenna module i've damaged it with screwdriver...the damage seem invisible but the antenna don't work...i've connected about 10cm of elelectric cable( like cable in pc fan) at the two pin of the green little antenna module on the bottom, where is connected black antenna cable then i start up the phone and i did operator search and it worked, i found all operator and indicator signaled a notch |
