Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-23-2015, 16:32   #1 (permalink)
Member: 284739
Thanks Meter: 9
xperia z3 compact backlight 100% tested solution
http://www.4shared.com/download/BSX7....jpg?lgfp=1000
The Following 5 Users Say Thank You to arion tonel For This Useful Post:
Old 02-28-2015, 14:10   #2 (permalink)
Member: 65061
Thanks Meter: 6
Any body can tell where is for z3 ?
Old 03-05-2015, 17:14   #3 (permalink)
Member: 2103455
What causes that problem?!
Old 03-14-2015, 21:15   #4 (permalink)
Member: 2359920
Hi, Solution for xperia ZR C5502 pls
Old 06-19-2015, 18:56   #5 (permalink)
Member: 2412935
Is there any video on how to fix it? Because i can't understand what to do. I got a new screen for my sony xperia z3c but there is no backlight and i can see the screen only outside.
Old 06-22-2015, 12:01   #6 (permalink)
Member: 284739
Thanks Meter: 9
just make a jumper on that little varistor
Old 06-29-2015, 20:21   #7 (permalink)
Member: 2418841
how do u make a jumper
Old 08-25-2015, 03:19   #8 (permalink)
Member: 1711137
I saw your fix on the fuse, but it's the first time the phone is opened and I never thouched the fuse because it's underneath a metallic plate, which I didn't even touch or moved. So I have a question as to why would I have to do something with the fuse if I never did anything to it and the screen was working when I tested it?? It just stopped working afterwards for some unknown reason.
The phone is on, because there is the blinking light. So, do you have some suggestions??? Should I actually try to add a jumper on the fuse??
Thanks.
EDIT: I remember that when I was about to close the phone I put the screen upside down by mistake, and it was when the screen backlight stopped working. Is this some reason why the fuse could have been damaged??? Or what would happen if I connected the screen upside down?? Could that create issues??
Thanks!!
Old 08-25-2015, 03:19   #9 (permalink)
Member: 1711137
Thanks.
Thanks!!
The Following User Says Thank You to aerismel For This Useful Post:
Old 08-25-2015, 03:43   #10 (permalink)
Member: 1711137
Sorry, for some reason I posted twice.
Old 08-27-2015, 01:16   #11 (permalink)
Member: 1007855
Thanks Meter: 27
xperia z3 lighting solution
100% tested solution for z3 back light
The Following 3 Users Say Thank You to rashadi For This Useful Post:
Old 09-25-2015, 05:20   #12 (permalink)
Member: 2463794
Hi how do you make a jumper on the varistor?
I replaced the screen on my Xperia Z3C and I can hear that the touch is working (clicking noises and vibration) but I can't see anything on the screen.
Old 10-08-2015, 11:35   #13 (permalink)
Member: 898996
Thanks Meter: 2
Tested and 100% Working solution, many thanks
Old 11-22-2015, 23:47   #14 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 64
FAkeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
this doesnt work
I JUMPED IT AND THEN IT MADE THE BOARD VERY HOT AND I SMELL BURNING FROM BOARD.
DONT TRY IT,
it will burn the board.
Old 12-10-2015, 14:35   #15 (permalink)
Member: 256978
Thanks Meter: 72
Z3 compact
This lcd light solution works 100%
Tnx bro
Page generated in 1.21801 seconds with 8 queries
