Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-10-2016, 17:29 | #1 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2640780 Status: Offline Thanks Meter: 1 | Xperia Z5 boot loop, backlight only I have a problem with my Sony Xperia Z5. One day on low battery it powered off, then it won't turn on. When turning on, I can see only backlight (no sony logo etc.), then after 5-10 sec it reboots and red led blinks 3 times. I actually tried software reset, so it probably should be HW issue. Phone has a not original replaced screen (working 2-3 months). But this issue also persist with original broken one. I see some similar topics but related to backlight issue.. Please help! |
The Following User Says Thank You to hadespl For This Useful Post: |
11-11-2016, 15:07 | #2 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516786 Status: Offline Thanks Meter: 0 | same problem i have same problem with this model, sony xperia z5 e6653. After screen replacement, when i turn on the phone: backlight on>backlight off> 3 times red leds> restart. Boot loop. There is one strange thing... when i turn on the phone without the LCD, it hasn't problem... because pc recognize it like mass memory. whit microscope i see nothing damaged.. filter works perfectly.. i don't know! |
11-12-2016, 02:17 | #3 (permalink) |
Member: 2640780 Status: Offline Thanks Meter: 1 | I have E6633 model. With screen disconnected it also keeps restarting. So you are lucky, and able to copy data from internal storage. I flashed mine many times after this failure. Maybe it is why it is not starting even with screen disconnected. Of course device is recognized in flash/fastboot modes and not rebooting with or without screen. |
11-12-2016, 10:43 | #4 (permalink) |
Member: 2516786 Status: Offline Thanks Meter: 0 | yes Yes, probably is your flash, but i don't know what it is, i tell the problem at the seller and he send me immediatly a refund, two display with the same problem, can it be only the display defected? A lot of display with this problem? |
11-17-2016, 20:55 | #6 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2648341 Status: Offline Thanks Meter: 0 | Hello, I have the same problem with several Z5 devices After replacing the display the mobile phone hangs in this reboot loop. Previously, the fuse on the LCD connector is usually defective and replaced by a jumper. The software is original and loaded with Companion. Does no one have an idea? |
11-21-2016, 16:09 | #9 (permalink) |
Member: 2640780 Status: Offline Thanks Meter: 1 | Like this one? fs5 . directupload . net / images / 160614 / 83w9wqjc . jpg Is there any way to check it before soldering? edit: sorry for spaces in link but I haven't achieve enough posts to send links |
11-27-2016, 14:55 | #10 (permalink) |
Junior Member Join Date: Nov 2016 Location: Bulgaria
Member: 2654145 Status: Offline Thanks Meter: 0 | Hello,i'm having the same problem and i did removed the fuse and made a jumper the LCD came back but when i turned it on Xperia logo and sony pop up and after 3 sec again black light and phone shutdown? any suggestions what can cause the problem ? |
