Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-12-2004, 16:52 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 77076 Status: Offline Thanks Meter: 7 | hi,tried that too infact i checked on board an discovered that the voltage runs through,yet it does not get to the charging tips on the board,plsss offer other options where available,anyone plss. |
10-15-2004, 12:24 | #6 (permalink) |
Member: 77076 Status: Offline Thanks Meter: 7 | Not charging(at all) hi,the problem is that the phone does not charge at all,and has n othing to do with the battery,pls assist with all posible solutions for (on board) not charging fault urgently,tanx.(Z200). |
10-16-2004, 14:04 | #8 (permalink) |
Member: 77076 Status: Offline Thanks Meter: 7 | z200 not charging hi, year2000 how is this option xpected to adress my problem,have you tried it before,did it work,if answers are affirmative then give me the details,tanx a lot for your response. |
10-16-2004, 14:15 | #9 (permalink) |
Member: 77076 Status: Offline Thanks Meter: 7 | z200 not charging hi,the actual problem remains that the phone works normally and the battery is ok,but it does not charge.I checked the board and found out that charge voltage enters through the board but terminates before reaching the tip on board(where from it contacts the battery connector to the battery)thus resulting in not charging fault,somebody plsss offer atentative solution,tanx. |
10-16-2004, 15:19 | #10 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | sorrsy i dont have the bord in service yet but i thing that the voltage must come to some tranzistor like t65 and the other part to baterymalso check fuse and resistance between gnd and Vcharge |
z200 not charging,another z200 mic problem. | de brain box | Sony Ericsson Hardware Repair | 3 | 12-10-2007 09:31 |
Z200 not charging - low charging | Yoda_Brno | Sony Ericsson Hardware Repair | 26 | 10-31-2007 07:33 |
not charging z200 | aranaar | Sony Ericsson Hardware Repair | 1 | 12-19-2006 09:27 |
Z200 not charging | ***GSM-LONI*** | Sony Ericsson Hardware Repair | 0 | 04-30-2005 14:41 |
Z200 not charging | Cat10 | Sony Ericsson Hardware Repair | 2 | 09-30-2004 17:18 |
