Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-31-2004, 11:50 | #1 (permalink) |
Junior Member Join Date: Oct 2004
Member: 89334 Status: Offline Thanks Meter: 0 | T100 key problems I want to open it up to see if I can clean it. I have removed the two screws at the bottom but it is still not opening. What do I do now? When it is open, what should I do to get the keys working again? Are there any good guides I can view somewhere? |
11-02-2004, 19:40 | #3 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | remove the antenna.and remove two screws are there.and slitely pushup and pull. after ur cleaning work carefully fix the side scroll key or other wice u lose that, thanks |
11-04-2004, 05:04 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Location: The great pakistan
Member: 79823 Status: Offline Thanks Meter: 26 | hi! they have told you how to open it now the problem with keys? clean the pcb well and check if not ok then you have to rehot the CPU the big IC in lower section but be care full i have killed one fone like that but i could repair it latter but with lots of pain wbr Daanish |
07-19-2008, 16:30 | #8 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 199996 Status: Offline Thanks Meter: 41 | t100 keypad problem is 99% side key prolem. u must remove and cheak I have solved one phone by removing side key. I think it is the right solution for keypad problems. Thanks regards Motaleb [email protected] |
sony ericsson T100 key problem | ranjit2003 | Sony Ericsson | 0 | 06-30-2006 13:17 |
t100 key pad failure | MARKIE41 | Sony Ericsson Hardware Repair | 1 | 07-15-2005 12:36 |
T100 key pad | buschell | Sony Ericsson Hardware Repair | 19 | 08-27-2004 21:08 |
T100 Flashing, Problems!! | gsmdeli | VLSI, Conexant, Skyworks and Old Models | 7 | 02-15-2003 03:27 |
** T100 flash problem ** | bluelights | VLSI, Conexant, Skyworks and Old Models | 0 | 10-13-2002 02:19 |
