Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UniMoto
Old 05-14-2005, 14:20   #1 (permalink)
legija
Guest
Posts: n/a
Member:
Unimoto 3.06 Beta
Hello,
We're pleased to anounce this newest version today.
- Added support for E1000 newest boot
- Fixed bug with A835 and A925 boots
- Full PDS rebuild for Triplets, R364 based (C650, V220, V180 etc) and V3 phones
Please download it from usual place.
New manuals coming (MPX220 and E1000) tonight or tomorow morning.
Old 05-14-2005, 15:34   #2 (permalink)
nik
nik's Avatar
Member: 127
dear sir a925 not working ,,after flash mode ,,first step is done ,,,and phone should power off this not happens ,,if try manuall after power up phone is connected and its opn pls wait phone connected in older ver it was fine i mean 3.01-3.02
pls rectify
reg
nik
Old 05-14-2005, 18:49   #3 (permalink)
GsmHgvnl's Avatar
Member: 82928
@Legija
and unlocking from Dutch Vodafone MPX200...is that problem solved ?
Old 05-14-2005, 19:49   #4 (permalink)
wiky's Avatar
Member: 28074
Unhappy Have unlocked one MPX200 but...
@Legija:
I have unlocked one MPX200 with the 306 very fine...
Try to unlock (Get code) one MPX220...
I have use the original motorola cable...no battery...charger connected to the cable...charge the usb drivers...din..don...dindon... and now open the 306... set to 220... unlock... get code xxxxxxxx disconnect the phone...close the 306... instal the battery... the scren turn on but in white...try to turn the phone on...NO WAY...THE MPX220 IS DEAD!!!.....
I try to format the phone and no probelem... have the good scren and answer yes... the formating is fine but at the end the phone is off and can't turn on!!!
PLEASE... ANY HELP!!!!
Old 05-14-2005, 20:05   #5 (permalink)
legija
Guest
Posts: n/a
Member:
Your battery is empty, simple.
You cant get codes if Unimoto loader is not running in phone. To achieve this, phone must be iniialized properly.
Old 05-14-2005, 21:18   #6 (permalink)
wiky's Avatar
Member: 28074
Wink O.K. Problem solved...
Sorry Legija but the battery is full...Now... the phone is alive!!! I try and try... and try... to format the phone... after five trys the phone turn on and is fine!!!
New problem with this 220... Can't unlock... the SIM do not acept the unlock...you know...
Any way... The phone is fine and I will not pay for the phone!!!
Thanks for your atention to my problem...
Regards.
Old 05-14-2005, 22:49   #7 (permalink)
Member: 129665
Originally Posted by legija
Hello,
thx
regards nice e1000 TEST ok
Old 05-15-2005, 00:00   #8 (permalink)
Member: 33060
please where is it ? thanks
Old 05-15-2005, 10:36   #9 (permalink)
nik
nik's Avatar
Member: 127
mpx200 work fine ,,,but
pls fix a920 and 925 ,,,they were fine in 3.02 ,,plssssssssssssssssss
reg
nik
Old 05-15-2005, 12:34   #10 (permalink)
legija
Guest
Posts: n/a
Member:
reg
nik
Can You describe Your problem with more details ? If this post is related to missing command "exit boot" - this was made with purpose, to avoid "Device not recognized" problem.
Now users have to remove battery from phone and restart manualy, which gives them chance to unlock phone even without reading manual (which hapens oftenly ).
Old 05-15-2005, 14:08   #11 (permalink)
nik
nik's Avatar
Member: 127
hi ,,,
i remove the battrey and power up phone ,,after its detected it says phone conected ,,
and it keeps wating for long time and then u have to select stop no othere option ,,i had tried with a hadset that was unlocked bu older version of unimoto.
i reistalled all drivers too.
same problem was confirmed by other people too.
reg
nik
Old 05-15-2005, 14:33   #12 (permalink)
legija
Guest
Posts: n/a
Member:
So, it's simple, You have to check for 2nd Murphy's law.
"If nothing works, read the manual"
www.unimoto.net/a835.html
Old 05-15-2005, 15:13   #13 (permalink)
nik
nik's Avatar
Member: 127
i did what manual says i have only locked a925 on unimoto ,,,so i think i not wrong done aproxx 50 phones earlier
Old 05-15-2005, 16:48   #14 (permalink)
legija
Guest
Posts: n/a
Member:
Come on MSN or ICQ, and lets see who's right.
[IMG] code is Off
Unimoto 3.15 Beta - C975, V975 added legija UniMoto 34 02-24-2006 12:00
Unimoto 3.16 Beta - V975 RSA update ! legija UniMoto 41 09-22-2005 18:52
Unimoto 3.14 beta - Backup introduce ! legija UniMoto 5 07-07-2005 22:56
Unimoto 3.13 Beta legija UniMoto 3 07-05-2005 09:59
Unimoto 3.02 BETA released !!! Mpx200 Bug fixed !!! - corect NCK now ;) claudio_gsm UniMoto 13 02-22-2005 20:23
Page generated in 0.36474 seconds with 11 queries
