02-01-2008, 09:01 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: uk
Member: 240930 Status: Offline Thanks Meter: 16 | A1200 after flash lost network and not work tuch screen pls help.... |
02-01-2008, 09:10 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ majidjonym What firmware version it originally had and what flash file have you used to flash it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-01-2008, 18:09 | #3 (permalink) | |
Member: 240930 Status: Offline Thanks Meter: 16 | Quote:
1.A1200_R532_G_11.00.44P_LP004D 2.a1200 - R532H2_G_11.20.06P 3.A1200_R532L4_G_11.40.0FR_LP0003B 4.SmartMobileA1200Windows.sbf 5.R532H2_G_11.20.12P_GSZHNANT677UL013_LP004DA_T677 UL_S015_E001_R004_G001_1FF.sbf but it have same problem! | |
02-03-2008, 10:29 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | dear just do Master Reset and Master Clear for A1200 and network will come. i get same problem with one A1200 so i just reset it from menu, and everything went goooood. try and post your result Take Care ENJOY |
02-04-2008, 10:44 | #9 (permalink) | |
master reset and master clear in the menu is disable!! | |
02-05-2008, 09:52 | #11 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
2) Connect S-Card with USB. 3) Connect Simply USB cable to Computer and Mobile. 4) After Installation of Drivers, open Scout software. 5) And Do Master Reset and Master Clear from Scout. Take Care ENJOY | |
The Following User Says Thank You to imran_qasim For This Useful Post: |
02-05-2008, 13:44 | #12 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
1. Tap on status bar in home screen. Switch off antenna tap ok on the bottom. Then switch on antenna again. (You may need to repeat this a couple of times) 2. If that doesn't work, change the network band to 850/1900 [dial pad-->menu button (at bottom left)-->setup--> network setup--> menu button--> search setup--> band and put it on 850/1900. After that close all those things and you should have service again. Once you get your service back, repeat the steps and put it on automatic again | |
The Following User Says Thank You to mcandre For This Useful Post: |
02-11-2008, 16:32 | #14 (permalink) | |
Member: 239548 Status: Offline Thanks Meter: 2,781 | JoAoOpAuLo, have you tried this? Quote:
A1200 NOT work tactile screen | jill23 | Motorola Hardware Repair | 0 | 03-20-2008 13:44 |
N80 after unlock no network and not charge | F@RUK S | MT-BOX | 22 | 09-28-2007 18:02 |
5210 after flash lost network every 3 mins | randy_d4 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-15-2004 20:35 |
2100 after flashing contact service and not connnecting with mbus,problem solved | monti_908 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 03-05-2004 10:10 |
