11-08-2008, 14:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: punjab india
Member: 421487 Status: Offline Thanks Meter: 58 | after unlock v31 0.30 r479 goes boot mode |
11-08-2008, 15:06 | #2 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Ist Prepair this phone with 0.30 boot-version and then flash with same or higher ver. . . it should b work. . . B.R., kashi4gul |
11-10-2008, 08:42 | #6 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ rohit50, First of all please tell us what firmware version the phone originally had and what flash files did you use to flash it. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-10-2008, 12:31 | #7 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | sir when i prepare phonetMoto 3.14 S-Card: 626***** Smart-Clip dongle, v 2.08, assigned Smart-Clip: 148******Europe, initializing... OK Clip serial: 148*****, version: 4.07, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Boot version 0x300 is not supported for model 'V3i,V3t' |
11-10-2008, 12:37 | #8 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | si what is this error now ican repar S-Card: 6******* Smart-Clip dongle, v 2.08, assigned Smart-Clip: 14****** Europe, initializing... OK Clip serial: 1******, version: 4.07, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Boot version 0x300 is not supported for model 'V3i,V3t' Operation log saved to "D:\v3i log\SmartMoto log 10-11-2008.txt" Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F128L18T, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 353623014825592 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 353623014825592 (14).mbk" Login request... OK Writing flash section 2 of 2... 100% (24.3 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (14.1 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Turning phone off... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Boot version 0x300 is not supported for model 'V3i,V3t'pds error is now what can i do costomer is very engey |
11-10-2008, 13:15 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ rohit50, Usually boot version get read as 3.00 in case if the set connected via TestPoint or the TP is shorted. Did you connect the set via TP? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-10-2008, 13:37 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ rohit50, If the set has boot version 0A.30 no need to perform TP procedure, it can be flashed/unlocked via Prepare cycle. Try to power on the phone and perform flashing procedure via Prepare cycle, Full Flash the set with the same firmware version like it originally had or higher one. Also, please tell us what firmware versions did you use to flash the handset. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-10-2008, 14:05 | #15 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ rohit50, Try to flash the phone with the R479_G_08.B5.3DR full flash file. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
W810 Cid49 after unlock locks 0 0 0 0 0 | gsm_ | SETool2 | 5 | 03-17-2010 02:19 |
I-Phone 3GS 32gb after unlocking via blackra1n always going 2 Recovery mode | madnan85 | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 02-04-2010 16:27 |
6125 ATD still not unlocked with 0.30 software | chrisro | BB5BOX | 10 | 01-15-2008 12:25 |
