02-22-2009, 19:58 | #1 (permalink) |
Banned Join Date: Oct 2008
Member: 877339 Status: Offline Thanks Meter: 15 | Boot_loader Login Problem with Smartmoto on USB Looking for clip on USB adapter... Exception: access violation at 03DADF95 Can anyone help please? Thanks |
The Following User Says Thank You to Top_Banana For This Useful Post: |
02-23-2009, 10:21 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please specify what exactly cable did you use to connect your Clip to PC? Are you using Smart Adaptor? Have you installed drivers? Best Regards GSMServer team |
02-23-2009, 14:47 | #4 (permalink) |
Member: 877339 Status: Offline Thanks Meter: 15 | No i'm not using Smart Adaptor, I have a USB to Parallel Port Cable which is similar to what Smart Adpator does (simply convert USB to Parallel). Yes the drivers are automatically installed by Vista. But still get this error when using Bootloader to see the smart clip. |
02-23-2009, 16:36 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | I don't think it will work with Smart-Clip. The only device that is fully tested and compatible with Smart-Clip - is Smart Adaptor. Best Regards GSMServer team |
02-24-2009, 14:31 | #6 (permalink) |
Member: 877339 Status: Offline Thanks Meter: 15 | Ok, instead I have connected Smart Clip to standard Parallel Adapator (PCi-express to Parallel card), but when I do connect it looks for a Hex address under LPT1, and says no clip found. Any ideas on how to set a Hex address for LPT1 under Windows Vista? The port options under device manager only say use interrupt, but doesn't actually let you assign one. Thanks |
02-24-2009, 15:08 | #7 (permalink) | ||
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Quote:
___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com Last edited by GSM_Support; 02-24-2009 at 15:29. | ||
02-27-2009, 00:55 | #8 (permalink) |
Member: 877339 Status: Offline Thanks Meter: 15 | Well I ended up having to buy a Smart Adaptor, and it works fine via USB and after updating firmware. I personally have to say that the cost of the cable is ridiculous, at the very least, for the price you pay, it should at least come with 6 months access to files... what do you say supporters? The smart cable is around 10x the cost of a standard usb to parallel cable. Thanks for the help anyway. |
02-27-2009, 14:39 | #9 (permalink) | |
___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com | |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
02-28-2009, 04:38 | #10 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Yes...not only time saver, but in times of trouble *your internet connection fails* or *server is down for maintenance* ...you are full working .... thanks to offfline PDS capability ! ,smokin |
02-28-2009, 22:40 | #11 (permalink) | |
Member: 877339 Status: Offline Thanks Meter: 15 | Offline PDS repair??? whats that about, and is it much a big deal? Is that better than access to files on boot loader for six months? thanks for all your replies by the way, great support here Quote:
Problem with smartmoto (could not get USB descriptor) | Jiminay2000 | Smart-Clip | 4 | 01-04-2008 17:04 |
problem with smartmoto | hwlabo | Smart-Clip | 9 | 02-05-2006 19:48 |
problem with smartmoto prog | wolfecom | Smart-Clip | 3 | 06-16-2005 21:25 |
Problem with smartmoto | Twister fan | Smart-Clip | 4 | 05-23-2005 17:14 |
