05-15-2006, 18:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | Motorola V3x not unlocking Here is log Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... 0x0070-0x00B1 (x2) Phone group: A835,A845,A920,A925 Internal error 0001 |
05-15-2006, 22:54 | #2 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
some times v3x can be a pain as i can see in your log that it hasn't detected the right group so keep trying till it says ok i had a problem on c975 and every time was an error but didn't give up so got sorted at the end good luck br | |
05-16-2006, 00:07 | #3 (permalink) | |
Registered User Join Date: Dec 2005 Location: algeria-tiaret
Member: 213203 Status: Offline Thanks Meter: 5 | Quote:
05-16-2006, 11:25 | #7 (permalink) |
Member: 2800 Status: Offline Thanks Meter: 47 | What the hell you say,phone is working properly,i think there is some problem with boot version 6.8.2,because i've done a lot of v3x,and only have problem with 2 pieces. I've restart pc and all things i can do but no way to unlock it. |
05-16-2006, 14:58 | #8 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | Flash microchip could not be detected. Apparently it got damaged during shield removing. Try to put some hot air on PCB, it might improve the connectivity & solve the problem. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-16-2006, 19:42 | #10 (permalink) | |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | Quote:
they donīt want to read ur post. V3X not need to remove any shield. do u remove test point before unlocking? usually u have to do it like this for V3X: start program Attach phone to smart clip without battery connect test point attach battery search for phone phone should be detected by program and SWITCHES TO FLASH MODE remove test point do what u want now with ur phone | |
05-16-2006, 19:51 | #11 (permalink) |
Freak Poster Join Date: Nov 2004 Location: romania Age: 43
Member: 91963 Status: Offline Thanks Meter: 34 | sonkar don't listen this bul...i was freeked when i see the support give you such an idea(go on support and take a look of testpoint gsm_support) man recconect your smart clip and try again,again,....for me he works.good luck |
05-17-2006, 01:02 | #12 (permalink) | |
IT LOOKS LIKE SMART-CLIP TEAM PRACTICES ON DIFFERENT V3X THAN US IT IS FUUNY THOUGH CUZ ONE ADVICES TO DOWNGRADE BOOTLOADER ON A V3R TO UNLOCK AND THE OTHER SAYS V3X DAMAGED DURING REMOVING SHIELD http://forum.gsmhosting.com/vbb/show...&highlight=V3R SUPPORT | |
05-17-2006, 09:02 | #13 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | OK, we use a standard replays, let's say that chip was damaged during disassembling, not the shield removing. What does it change? Flash chip still can not be detected and still needs to be repaired. Regarding V3r. It could be unlocked via downgrade boot method, as most of the phone models, it just needs done as V3i. There is nothing wrong on that recommendation. Any more suggestions? Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-17-2006, 10:07 | #15 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | It requires to be connected with testpoint to be flashed. Direct flashing with *.shx files will be added in future. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
motorola c115 not unlock | shabeermobile | Infinity-Box | 7 | 08-18-2009 07:54 |
motorola v3x not power on | iliralla | Motorola Hardware Repair | 2 | 08-08-2009 18:18 |
Motorola V3x Free Unlocking Tool | Rana Bose | Motorola P2k | 0 | 07-10-2007 12:24 |
Motorola V1075 not unlocked with GOT | deska | GOT Motorola | 4 | 01-16-2007 19:14 |
Motorola Clip2 not unlock C350 | lypen17 | Motorola P2k | 3 | 02-06-2004 20:42 |
