can Sc team write how to change imei on Moto phone ? please write step by step what to do...thanks. |
re imei You can find Write IMEI (International Mobile Equipment Identity) function under Service tab of SmartMoto. Up to date list of models directly supported by this feature includes Motorola V60, V66, T280 and V70. Another option is to use "IMEI firmware patch" function, which works with most of supported models. To write IMEI into other models you would have to replace FLASH chip with new one having blank OTP zone. Connect your phone to PC via Smart-Clip. Launch SmartMoto. Program should detect the handset. Open "Service" tab. Enter any 14 digits into "Phone IMEI" field and press "Write". Close SmartMoto. Disconnect handset. Restart the phone. Handset with new IMEI is ready to use. IMEI change using "IMEI firmware patch" functionPress "Search" to detect the phone (should be able to turn on) Press "IMEI firmware patch" in "IMEI" section and wait until the operation completes Turn the handset on and press "Search" Input new IMEI into "Phone IMEI" field and press "Write", reboot the phone, and check new IMEI (using *#06# keycode or via SmartMoto function) cheers wolfe |
i did not understand ? we can change imei only on new chip ? or we can change imei on any MOTO phones we wanna even on BLOCKED phones ? |
on any phones mate, smart moto will now patch any listed phones to any imei you like, and yes even blocked phones. |
http://forum.gsmhosting.com/vbb/show...5&postcount=46 :( |
it change imei or not i refer like nokia DCT3 and patch file to DCT4 NEW CHIP:confused: :confused: some explain the this PORTUGAL RULEZ |
hi so easy, you have to remplace flash chip, now phone have no imei no id data, you write new imei, flash otp zone is write with correct id data, and phone have new imei and registering ok (both imei&display imei were changed), if flash chip is not changed id data still remain same and imei is not changed unless display imei was, best regards Invisible |
I really can't believe that SC team would release an update with out checking it first. |
v220 i tried with a v220 it changed the imei on de screen but it is also still barred and another problem is the phone restarts it self now..so i flashed it with its original backup and security zone imei changed back to original but the phone continues to reset itself this is a brand new phone..any ideas? BR gee4234 |
