08-29-2010, 19:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | l7 dead with smart i forget to backup full flash l7 now phone is dead ;i try with many versions still dead i try also with same version before flashing V360--_R4513_G_08[1].B7.AER_lp002C_full_flash still dead what can i do with this l7 ??? |
08-30-2010, 07:17 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bendou, Please provide us with more detailed information. What had happened to the phone? What procedures did you perform What flash files did you use for the flashing purposes? Best Regards GSMServer team |
08-30-2010, 10:41 | #6 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | phone was blinking with simcard and firmware inside was R4513_G_08[1].B7.AER ,i try to flash it without testpoint " prepare phone methode" with some sw : R4513_G_08.B7.ABR_RB R4513_G_08.B7.DCR_RB and also V360--_R4513_G_08[1].B7.AER_lp002C_full_flash but still dead |
08-30-2010, 10:44 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bendou, First of all why did you flash the set with V360 firmware version? Also, please tell us, whether you perform Repair PDS procedure before flashing the set or no? What is current state of the phone? Best Regards GSMServer team |
08-30-2010, 11:38 | #8 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | hi; i don't have access to support area to downlaod the same flash file i download it from rapidshare ,and did not make repair pds and forget to make backup phone is in flash mode and show nothing on lcd thx for reply |
08-30-2010, 11:55 | #9 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bendou, Try to perform Repair PDS procedure and after that Full Flash the set with the R4513_G_08.B7.DCR_RB. After that please post results here. Best Regards GSMServer team |
08-30-2010, 12:59 | #10 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | repair pds and flash with R4513_G_08.B7.DCR_RB done, keypad blink blue light and go off i can put phone in flash mode manualy and it show boot loader versions |
08-30-2010, 13:05 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bendou, Show us log file from Repair PDS and Full Flash procedures, don't forget to hide serial numbers. Best Regards GSMServer team |
08-30-2010, 13:10 | #12 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 353925xxxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 353925010xxxxxx (7).mbk" connecting to server... cannot connect to the server Login request... OK Writing flash section 2 of 2... 100% (24.1 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.6 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (46.7 Kb/sec) Turning phone off... OK Flash completed! |
08-30-2010, 13:39 | #13 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bendou, One of possible reasons for such problem to appear could be that the phone was flashed with the wrong platform firmware version. try to perform following steps: 1. Make Repair PDS for R4513 platform 2. Flash the phone with R4513 firmware version (the highest one) 3. Perform IMEI patch. 4. Restore ORIGINAL IMEI using SmartMoto Restore IMEI option. NOTE: Phone cable should not be disconnected during the whole process until the last step is performed. After that post results here, along with the log files. Best Regards GSMServer team |
08-31-2010, 11:04 | #14 (permalink) |
Member: 165971 Status: Offline Thanks Meter: 65 | Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.5 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (16.6 Kb/sec) Flash completed! Applying IMEI patch, please wait (up to 2 minutes!)... OK IMEI patch successfull, set new IMEI with the "Write" button Writing new IMEI 3539xxxxxxxx... OK Turning phone off... OK now phone show boot loader menu when battery inserted without press on and say phone code sig error: thx in advance. |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
