Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 08-11-2008, 11:43   #1 (permalink)
Member: 60831
Thanks Meter: 11
Can't update scard - please help
I install new clean system instalation, new version of smartmoto and can't update scard to newest version.
Old 08-11-2008, 11:51   #2 (permalink)
Crazy Poster
Member: 277876
Thanks Meter: 2
hi
check r u using the same smartclip that is registered with the scard
d.g
Old 08-11-2008, 12:09   #3 (permalink)
Member: 60831
Thanks Meter: 11
Originally Posted by Dawoodgalaria View Post
hi
d.g
yes it is. I have only one complet (smart-clip+scard)
Old 08-11-2008, 12:13   #4 (permalink)
Crazy Poster
Member: 277876
Thanks Meter: 2
http://www.gsmserver.com/smartclip/S...pdate_Zone.php
If u r trying to update ur scard use this link
dg
The Following User Says Thank You to Dawoodgalaria For This Useful Post:
Old 08-11-2008, 12:45   #5 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
The S-Card update procedure has been changed. Please check out the manual.
S-Card registration/update procedure
  1. Please be aware that S-Card registration/update procedure requires a stable Internet connection during the whole process.
  2. Connect S-Card dongle to PC USB port;
  3. Connect Smart-Clip to PC using Smart Adaptor or LPT cable;
  4. Power Smart-Clip ON (warning: don’t use battery!);
  5. Go to our Update Zone at http://www.smart-clip.com/upgrade.php;
  6. Update Zone uses ActiveX control, answer "Yes" to install and run it;
  7. Log to the S-Card tab;
  8. Press "Update" button;
  9. An ActiveX client should detect Smart-Clip serial, firmware version and S-Card serial, update process begins;
  10. New firmware is loaded.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
I can not update my scard please help me out MUTUAL Smart-Clip 4 01-28-2010 03:08
I can't update scard and smartclip tuban_gsm Smart-Clip 1 12-09-2009 07:51
SCARD update problem..please help me..!! argentino Smart-Clip 2 05-04-2009 09:39
scard update problem!!!please help Leonhart_Gsm Smart-Clip 4 03-28-2009 10:39
Can't Update HWK, Please Help tersace HWK 5 04-15-2008 20:58
Page generated in 0.14617 seconds with 9 queries
