01-27-2007, 16:22 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 44
Member: 64311 Status: Offline Thanks Meter: 110 | Could not get usb discriptor After latest update of smart clip v3.12 i having problem of "could not get usb discriptor" Bellow is the log SmartMoto 2.16 S-Card: 5********6 Smart-Clip dongle, v 1.12, assigned Smart-Clip: 8********7 Europe, initializing... OK Clip serial: 8*******7, version: 3.12, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.53.1AR Switching to flash mode... could not get USB descriptor Check if the phone battery charge is OK Voltage out put checked is ok. smartclip totaly stop working after this update, before this everything was working fine If any one having same problem and can solve please reply Your help will be appreciated Thanks Rocky |
01-27-2007, 18:03 | #2 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
And I have solved it by charging phone's battery. Please make sure that the battery fully charged. And please read this thread just in case It should help. | |
01-29-2007, 06:20 | #3 (permalink) |
Member: 64311 Status: Offline Thanks Meter: 110 | To mcandre bro i am using smartclip since its early launch. I have been checking all possiblity pertaining to this fualt. Seems like there is problem after update. or may be it is hardware problem. Anyone else can share experience |
01-29-2007, 08:19 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ i_am_rocky, Check mini USB connector in the handset. Probably it has some malfunction. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-01-2007, 09:06 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ i_am_rocky, Please try to update your Smart-Clip and PM me log file. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-01-2007, 08:58 | #8 (permalink) |
Member: 64311 Status: Offline Thanks Meter: 110 | to all Problem solved...sorry for posting the solution so late. My problem was withing resistor just near to usb hub of the pcb i changed it and smart clip on again Hope this help others whos having same problem like me and yet not be able to repair. Regards |
03-07-2007, 09:19 | #10 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What version of SmartMoto do you use? How many phone models did you get that error with? Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-10-2007, 20:35 | #11 (permalink) |
No Life Poster Join Date: Dec 2004 Location: 0x001FD00
Member: 98572 Status: Offline Thanks Meter: 36 | the last one i remember is on l6, bnut i think it also not working with E1, E398 also, the problem raise only the phone in flash mode. but now i already sorted the problem. The problems are: 1. The Smart CLip's USB connector on the board. The ground of the USB conenctor shield is shorting out the BIG resistor pin, the resistor is connected via the power supply line. If you opened up the the Smart CLip you can get the idea what i'm talking about, since when i writting this the box isn't here, thus i cannot show you the picture or photo. Then i have to modified my box a bit. I remove the resistor and solder on the bottom of the board so it cannot short with the USB connector ground. THis is intermitent problem, when you plug the usb too hard a little the circuit will short. better design a better PCB next time. I'll help you if you want. 2. The Smart USB VOltage is too low (4,45 V). so i jumper out 5,00 volt right from the 7805 IC output to the USB V+. Now my smart clip work like charm..... Good Luck... |
03-13-2007, 08:33 | #12 (permalink) | |
Member: 64311 Status: Offline Thanks Meter: 110 | yep smartclip pcb layout need to be changed, *** save me Regards, Quote:
07-13-2007, 09:57 | #13 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239581 Status: Offline Thanks Meter: 0 | my smatclip shows error SmartMoto 2.24 S-Card: xxxxxxxxxx Smart-Clip dongle, v 1.25, assigned Smart-Clip: xxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 3.18, initializing... OK Searching for phone... found ¥, getting test interface... could not get USB descriptor. no phone is connected |
07-13-2007, 10:06 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ajinsjoseph, Please write a letter to support[at]smart-clip.com with log file, description of the problem and serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-10-2008, 08:53 | #15 (permalink) | |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | Quote:
I have same problem no power on led and no usb detection of any phone . upgrade ok rj 45 ok. please guide me . br. | |
could not get USB descriptor | scutarus | Smart-Clip | 15 | 06-02-2009 07:44 |
The E6 conjunction TP point the Smart-clip appear the descriptor of the could not get | ttlin5188 | Smart-Clip | 4 | 06-27-2008 09:43 |
could not get USB descriptor L6i | wyroskl | Smart-Clip | 5 | 11-10-2006 20:52 |
5110 -could not get mobile sw | baraka42 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-26-2003 19:06 |
