02-14-2006, 20:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: USA Age: 41
Member: 167428 Status: Offline Thanks Meter: 2 | Dead E1 Rokr!!! What To Do?? I have a problem after trying to unlock the E1 ROKR. The thing is that I alrady unlocked this phone before but this time something went wrong. Everything seemed to work fine when I was doing the unlock. 1st log: SmartMoto 1.15 Clip serial: 566xxxxxx, version: 2.22, initializing... OK Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... interface not found (connected testpoint) Switching to flash mode... OK [S Blank Neptune LTE] Reading phone boot version... 2.00 Reading flash id... 0x0010-0x8810 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 37F8A29B4870D09 Security area saved to "Motorola Phone (E790 iTunes) 37F8A29B4870D09.pds" ...(nothing after that) (I press search again)...Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... no phone found (I tried again) Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... interface not found (now I used testpoint) Switching to flash mode... OK [S Flash Neptune LTE] (now I press unlock via testpoint) Reading phone boot version... A.02 Sending boot... load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start (I tried again) Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... interface not found Switching to flash mode... OK [S Blank Neptune LTE] Reading phone boot version... 2.00 Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002107081 Security area saved to "Motorola Phone (E790 iTunes) 356389002xxxxxx.pds" Preparing... sector erase error (I tried to turn phone on, Now phone is dead) Phone only turns on as "S Blank Neptune LTE" or "S Flash Neptune LTE" Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx.pds" Writing section0 8000/10000... 50% 55.4 Kb/sec sector erase error Extended sector erase error code is A8 I tried to write fullflash from Boot-loader.com (R372_G_0E[1].20.C1R_lp002E_full_flash.smf) Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (31).pds" Writing section0 boot 10000/10000... 100% 27.1 Kb/sec sector erase error Extended sector erase error code is A0 I tried agan this morning using smartmoto repair Tab and selecting E398: SmartMoto 1.15 Clip serial: 566xxxxxx, version: 2.22, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (28).pds" Login request... OK Writing section0 10000/10000... 100% 26.1 Kb/sec sector erase error Extended sector erase error code is A0 Phone doesn't even pc flash!!! nothing works for it I even tried to write a bootloader again (found on Motomodders.com). I even the backup of the flash but "Extended sector erase error code is A0" when i tried to restore it. Please Help me. What should I do? |
02-15-2006, 08:23 | #2 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 48048 Status: Offline Thanks Meter: 7 | you read anything about unlocking this phone before you started? first you connect tp, then connect battery, hit search.. then disconnect tp, and hit unlock.. 20 seconds later, the phone is unlocked. unfortunately you screwed up, big time. the first time, you connected the tp too late. "Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... interface not found (connected testpoint) Switching to flash mode... OK [S Blank Neptune LTE] Reading phone boot version... 2.00 Reading flash id... 0x0010-0x8810 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 37F8A29B4870D09 Security area saved to "Motorola Phone (E790 iTunes) 37F8A29B4870D09.pds" ...(nothing after that)" the second time, it wasnt connected at all.. "Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... interface not found (now I used testpoint) Switching to flash mode... OK [S Flash Neptune LTE] (now I press unlock via testpoint) Reading phone boot version... A.02 Sending boot... load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start" then you panicked and this is where you should have asked for help. ok but there is still hope. maybe. unfortunately, you try E398 pds repair, then you just went ahead and decided that the bootloader needs to be replaced heh.. the good thing is since its a RSA protected bootloader and you didnt actually erase anything.. cause you never properly got the tp working.. you can probably fix it.. here is what you do.. you connect the TP to ground.. you hook up the battery... you push search.. if you see Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found this phone can be fixed by correct FULL_FLASH file. dont forget to take the tp off before you flash. also might want to check overwrite boot file since you messed at up too. good luck |
02-15-2006, 20:21 | #4 (permalink) |
Member: 167428 Status: Offline Thanks Meter: 2 | Still No Luck :( Well I tried again 3 times this morning... I will wait for reply to try different solution 1st try with R372_G_0E[1].20.C1R_lp002E_full_flash.smf (Connected TP and hit search) initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK (disconnect TP and write flash, overwrite boot area is checked) Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (39).pds" Preparing... clip communication failed (????) (I tried again, connect TP and search) Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK (disconnect TP and write flash, overwrite boot area checked) Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx(40).pds" Writing section0 boot 8000/10000... 50% 60.1 Kb/sec sector erase error Extended sector erase error code is A8 2nd Try with E398_boot_7[1].D.0.smf, found on Boot-loader.com this morning (connect TP and search) initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK(disconnect TP and write flash, overwrite boot area checked) Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (41).pds" Writing section0 8000/10000... 50% 60.1 Kb/sec sector erase error Extended sector erase error code is A8 3rd try with E398 PDS repair (connect TP and search) initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK(select repair PDS) Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (42).pds" Login request... OK Writing section0 10000/10000... 100% 26.1 Kb/sec sector erase error Extended sector erase error code is A0 What is the problem??? What Full_flash should I use for E1 Rokr from Cingular US? What am I doing wrong? Thank you all for your help. |
02-16-2006, 14:12 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | Repair PDS is not available for E1 yet. Please wait for future updates... Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-16-2006, 14:30 | #6 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Quote:
02-16-2006, 19:48 | #7 (permalink) |
Member: 167428 Status: Offline Thanks Meter: 2 | Great... So no way to fix that phone for a couple more weeks. Well I'm just wondering why making unlock solution and not making repair solution in Case something goes wrong? Is there anything else I can try to fix that, It got to have a solution? |
02-16-2006, 21:48 | #8 (permalink) |
Member: 48048 Status: Offline Thanks Meter: 7 | when you tried to repair pds with e398 it messed up the phone.. it does warn you that using other models can be really bad. try this, restore the security area with the first pds that has the real imei number.. you probably killed it with the E398 boot loader.. let me check some stuff out you want R373 files, not R372 |
02-17-2006, 05:43 | #10 (permalink) |
Member: 167428 Status: Offline Thanks Meter: 2 | The only option that works is the repair PDS option, I successfully restore one of the old PDS backup: Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356389002xxxxxx Security area saved to "S Blank Neptune LTE 356389002xxxxxx (44).pds" Writing security area... done |
02-17-2006, 05:57 | #11 (permalink) |
Member: 48048 Status: Offline Thanks Meter: 7 | yeah but i would have chosen a PDS from the E790 before it was blank. Hardware IMEI: 356389002107081 Security area saved to "Motorola Phone (E790 iTunes) 356389002xxxxxx.pds" |
02-17-2006, 06:30 | #12 (permalink) | |
No Life Poster Join Date: Dec 2003
Member: 47384 Status: Offline Thanks Meter: 8 | Quote:
If you live in Bay Area (North CA) please contact me for repair that phone. [email protected] | |
02-17-2006, 09:54 | #14 (permalink) |
Junior Member Join Date: Jun 2005 Age: 45
Member: 154267 Status: Offline Thanks Meter: 2 | When you doing TP Method, are you spose to hook it up to the Smart-Clip Box? or directly to the computer when you do the unlocking? Or are you spose to get the Neptune msg. and then unconnect the USB from the computer and move it to the smart-clip and then do the unlocking? |
02-17-2006, 14:22 | #15 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | Quote:
Phone must be connected to PC via Smart-Clip... Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
Blackberry 8320 (NEW) DEAD plz suggest what to do | riskyboi | BlackBerry (RIM) | 2 | 07-18-2009 12:33 |
UFS dead Please help what to do? | KUBAT1 | UFS2 + UFS3-Tornadoflasher | 23 | 09-04-2008 16:50 |
M55 Dead :( what to do? | pakstar | E-Gold Based Phones | 2 | 06-08-2004 21:02 |
Battery dry, phone dead what to do? | awyeong | x1x to x45/x50 | 1 | 04-16-2003 18:27 |
S40 Dead, what to do? | AlQuds | x1x to x45/x50 | 1 | 10-23-2002 03:08 |
