02-14-2008, 06:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | Error In V3xx pls. help V3xxSmartMoto 3.08 S-Card: 4*******Firmware R26111MLD-AS_U_96.B0.0AR Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 3.08 Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_0F03010544B64450.bk_ Reading data..OK Processing data, 6 of 6 block...OK Searching for phone... found Motorola Phone (RAZRV3xx), getting test interface... OK Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 3.08 Sending boot... OK failed error 80 pls. help .. Thanks |
02-14-2008, 08:17 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ karikari, This phone model can be unlocked using Preare Smart TestPoint procedure and Smart TestPoint cable. It looks like Smart TestPoint cable wasn't used in this case. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-16-2008, 23:15 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Unknown SmartClip Test point cable Quote:
Can some one help me determin the cable I got. I am a new user of smart clip. I was trying to unlock a V3XX 3.08 cingular phone. When I try connecting test point. I keep getting an error that phone not phoned. THE CABLE I GOT HAS 2 RED WIRES 1 WITH HOOCK AND ONE WITH CLIP. iT HAS ALSO A GREEN AND ONE YELLOW. Can this cable be used. Was purchased from GPG. | |
02-18-2008, 08:50 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ beerfoote1, We recomend to use original cables manufactured by our team, only. The cable that you have described wasn't manufactured by us, definitely. Original Smart TestPoint cable can be found here. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-18-2008, 22:45 | #5 (permalink) | |
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
errors in ub pls help me ub team | ashokassag | Universalbox | 10 | 09-29-2009 06:56 |
V3re Reconnect error in unlocking.Pls help | maeane | Smart-Clip | 9 | 02-19-2009 17:17 |
Nokia E65 error in flashing, pls help | fullbar88888 | Universalbox | 10 | 10-16-2008 16:27 |
Error in CDR Pls Help me.... | sharaz191 | Infineon C16X M51 & ARM7 M52 BASED | 0 | 03-31-2006 09:54 |
Error in Box! pls help??? | proxy_gsm | SagMaster Team OLD Products | 5 | 08-03-2004 08:29 |
