05-04-2008, 10:34 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | Foma M1000 error 80 upon Remove RSA. S-Card: 8yobb Smart-Clip dongle, v 2.08, assigned Smart-Clip: 8yobb Europe, initializing... OK Clip serial: 8yobb, version: 4.07, initializing... OK Searching for phone... found FOMA M1000, getting test interface... OK Model M1000 Firmware M1000_U_36.19.13P Switching to flash mode... OK [S Flash Rainbow POG] Reading phone boot version... 6.12 error 80 Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start does anyone encountered this problem? Procedure I used is tru Unlock Tab, And removed RSA, Sending boot for 81% then it shows that message.... Never try TP solution yet.... Got no TP, only have TP version 1 for 702is is that fit? Thanks for the support |
05-05-2008, 07:18 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ yobb, M1000 with boot version 6.12 can be unlocked using Remove RSA option. No need to use TestPoint. Please ensure that the battery fully charged and run unlock procedure once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2008, 12:34 | #4 (permalink) | |
Member: 337450 Status: Offline Thanks Meter: 718 | Quote:
Motorola M1000 Error 80 | rushwhq | Smart-Clip | 4 | 06-06-2008 11:28 |
FOMA M702iS error 80 not unlock | nafg | Smart-Clip | 2 | 11-27-2007 05:56 |
foma m1000 cant found after error rsa | brabbsss | Smart-Clip | 11 | 09-12-2007 06:15 |
Remove RSA -> I/O Timeout Error | Veritable | Smart-Clip | 3 | 03-29-2006 00:13 |
T630 R6D after remove RSA - Div show for flashing error 0102 | ducati907 | Sony Ericsson | 8 | 12-02-2004 16:26 |
