Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 07-07-2008, 03:58   #1 (permalink)
Orange_Dominica's Avatar
Member: 88701
Thanks Meter: 381
W490 B00t 4.00 to 0C.50 Success
SmartMoto 3.14
S-Card: Smart-Clip dongle, v 2.08,
Clip serial: version: 4.07, initializing... OK
Searching for phone... no phone found
Searching for phone... found Motorola Phone (W490), getting test interface... OK
Model W490
Firmware R452G_G_08.24.02R
Switching to flash mode... OK [S Flash Neptune LTE2]
Reading phone boot version... C.50
Sending boot... OK
Stored temporary backup to C:\
Sending boot... OK
Erasing flash memory OK
Sending firmware OK
Searching for phone... found S Flash Neptune LTE2
Reading phone boot version... 0.00
load error-----> (BECAUSE TP#2 CAME IN CONTACT WITH OTHER COMPONANTS WHILE REMOVING!)
Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found
Sending boot... OK
Sending firmware OK
Reading flash id... ST - M30L0R8000B0
Reading flash id/2... ST - M30L0R8000T0, OK
Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3
Hardware IMEI:
IMEI OTP status: locked
Security area saved to "PDS for S Flash Neptune LTE2
Performing restore from temparary backup file C:\
Restore OK
Unlocking phone...
error 9B-----> (THE DREADED 9B ERROR...SO WE MUST PREPARE AGAIN )
Turning phone off... OK
Model W490
Sending boot... OK
Stored temporary backup to C:\_
Sending boot... OK
Sending firmware OK
Reading flash id... ST - 880C, chip unidentified <--- LOOK AT CHIP ID !
Hardware IMEI:
Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found
Reading phone boot version... 4.00
Boot version 0x400 is not supported for model 'W510,W490'
After Removing a SMALL piece of shield and cleaning the PCB, We are READY !
Reading phone boot version... C.50 --->(SWEET !)
Sending boot... OK[/COLOR]Erasing flash memory OK
Sending firmware OK
Searching for phone... clip communication failed
Searching for phone... clip communication failed--->(SC froze!. So we must unplug, and Prepare again !)
Clip serial: , version: 4.07, initializing... OK
Sending boot... OK
Sending firmware OK
Hardware IMEI:
Restore OK
Unlocking phone... OK
;smokin
The Following User Says Thank You to Orange_Dominica For This Useful Post:
Old 07-07-2008, 10:18   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
Thanks for sharing your experience. It will be useful to other forum members.
Best Regards
GSMServer team
Old 08-24-2008, 18:54   #3 (permalink)
rudyandremely's Avatar
Member: 108193
Thanks Meter: 70
yea ok but what about the w490 that allways remain in blank mode and even After Removing a SMALL piece of shield and cleaning the PCB phone allways is boot 4. what to do in that case?
i mean how to come out from boot 4.00?
Old 08-25-2008, 03:28   #4 (permalink)
Member: 747913
Thanks Meter: 2
Just put the testpoints on right position, and all will be fine...
B,R
Old 08-25-2008, 03:44   #5 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
need proper connection testpoint to pcb....
Old 09-03-2008, 23:21   #6 (permalink)
Member: 285074
Thanks Meter: 20
ok my w490 says smart clip fail. y try severasl time to prepair , but always the same history... so... my phone is now in flash mode. but with CODE CORRUPT <......
with this problem ...WHAT CAN I DO...
I TRY TO FLASH IT with scout.
and here is the error
Phone model
IMEI
User code
Security code
Operation band
Firmware ERROR,NOT FOUND!
Flex version ERROR,NOT FOUND!
SCout 1.10. Flashing phone "S Flash Neptune LTE2 - ERROR,NOT FOUND!" with firmware "C:\M.O.D.E.L.O.S M.O.T.O\W490 FLASH SCOUT\R452G_G_08.24.02R_DRM0113_LP0003_GSVPEMBATMB 03NA0D2_1FF[T-Mobile locked].pcf"...
Preparing firmware image...
Loading RAM downloader for bootloader...
Erasing flash memory...
Error erasing subscriber unit. Device API Error: 0xE0020083 Command: ERASE
Flash failed
Old 09-04-2008, 00:44   #7 (permalink)
Member: 88701
Thanks Meter: 381
Hi..
Post a log from SmartMoto and your bootloader display
;smokin
Old 09-04-2008, 22:07   #8 (permalink)
Member: 481823
so, step by step? how is it?
you are saying that... boot 04.00... is not hardware damage as A L W A Y S Mr. Tinkertrain said?
BR!
Old 09-04-2008, 23:00   #9 (permalink)
Member: 285074
Thanks Meter: 20
Old 09-05-2008, 00:05   #10 (permalink)
Member: 285074
Thanks Meter: 20
and this is the error with scout
Old 09-05-2008, 01:29   #11 (permalink)
Member: 167930
Thanks Meter: 5
this unit always pain in the head when unlocking even the lastest update cant even cure
so it basically a luck when this unit has been fixed...
Old 09-05-2008, 01:49   #12 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
check ur TP adapter or try it with another unit, it look like not working or not connected properly
br
Old 09-05-2008, 02:02   #13 (permalink)
Member: 805196
Thanks Meter: 12
check the tp sir.....maybe its have a problem w/ your tp.....
good luck
Old 09-05-2008, 07:34   #14 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
Originally Posted by bachatia View Post
ok my w490 says ...
Looks like PDS zone is corrupted.
Old 09-05-2008, 16:50   #15 (permalink)
Member: 108193
Thanks Meter: 70
B,R
what do you mean put testpoint before to clic prepare buton? !cos when i try to prepare samrtclip allways say boot 4.00 not suportes and phone can not be prepared even if i conect the tespoint in right position. so we stock in boot 4.
The Following User Says Thank You to rudyandremely For This Useful Post:
How to Downgrace 4.0633.74.00 To 3.0633.69.00 alanchua1314 Nokia Base Band 5 ( BB-5 ) 0 05-13-2009 21:42
W490 Success Unlock 0C.50 oliverous Smart-Clip 1 07-20-2008 05:32
unlock w5 with 0C.50 cordd Smart-Clip 3 04-09-2008 23:54
w490 boot 0c.50 sw version; not found zeroualot_7 Smart-Clip 1 01-09-2008 16:10
Fighter 4.00 and Interceptor 4.00 released Lead Cruiser Suite 77 10-04-2004 10:08
Page generated in 0.32370 seconds with 11 queries
