12-10-2008, 23:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 258823 Status: Offline Thanks Meter: 2 | gsmserverteam help |
12-11-2008, 08:24 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ zongogsm, Did you try to use second mirror for the update procedure? If no, please try. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 12-11-2008 at 10:44. |
12-11-2008, 10:45 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ticcarsgsm, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights 8. You should clear cache of your browser and restart the computer. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SM-tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" After that try to run update procedure once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
help [ANSWERED] | mariusgsm76 | Nano-Box | 2 | 04-01-2010 11:33 |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
please help me to unlock N97 [ANSWERED] | longgiang81 | Genie Universal | 2 | 03-30-2010 09:18 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
