04-05-2006, 22:18 | #1 (permalink) |
Major Poster Join Date: Apr 2006
Member: 254722 Status: Offline Thanks Meter: 0 | Help with E770v unlock If possible ken someone help me please. after the test point( after s flash rainbow pog appear), i didnīt no wath to do, i disconet the phone and i tried to unlock just using smart clip and phone and i didnīt have any success. After that i done the test point again and i pressed search, unlock, chose e770v, unlock via test point, and the result was this: Clip serial: 758******,version 2.23,initializing ... ok Searching for phone...found motorola phone(E770v)getting test interface...ok Model E770v Firmware r25221_u_85.83.e1p reading info ok switching to flash mode...ok [s flash rainbow pog] reading phone boot version...6.71 boot prepare... failed That itīs the problem that i have, if someone ken help me please i donīt no wath to do, iīm newbie i just started now. Tanks to all best regards |
04-06-2006, 01:06 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | you should use unock via testpoint after you conected phone with TP.mate do like this: conect cable to phone without batery conect TP now conect batery Press search in smart moto flash rainbow pog found now press unlock via testpoint you will see boot version 3.10 hold tp for 2-3 seconds then release and it will be unlocked in a few seconds after that |
04-06-2006, 01:48 | #4 (permalink) |
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | yes if you do it fast or if you solder a wire to tp and touch it to gnd,cause you do not have 5 hands,remember,somebody must press search button |
04-06-2006, 03:59 | #5 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | This is instruction to Unlock E770 and E770v the same. 1- You must Disssemble the phone 2- Connect USB cable to phone (Not need to repair) 3- connect tesetpoint to ground 4- Connect phone battery 5- Press "Search" button in SmartMoto 6- SmartMoto should find "S Blank Neptune LTE" or "S Blank Paragon POG", or "S Blank Rainbow POG" 7- Disconnect test point 8- The phone is ready for theUnlock or flash/repair operations now. Hope you enjoy it . This is full solution to Unlock success E770. I'm have test 5 phone E770 and E770v is Ok . Best & regards |
04-06-2006, 20:33 | #6 (permalink) |
Member: 254722 Status: Offline Thanks Meter: 0 | Hello, my friends --- IKI --- NCTRUNG_VN --- DR-MEHDI --- Tank you very mutch for the help that you all give to me.The unlock was a big success. It was my first TP, for sure the next TP will be easier, now i understand how it work. The problem was the rong tp that i was doing Once more TANK YOU ALL VERY MUTCH Best regards upa |
04-07-2006, 16:36 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsmtower.com
Member: 226755 Status: Offline Thanks Meter: 198 | //////////////////////////////////////////////////////////////////////// Last edited by GSM_Support; 04-08-2006 at 11:56. Reason: Contained serial number |
04-07-2006, 20:44 | #8 (permalink) |
Member: 254722 Status: Offline Thanks Meter: 0 | Hello, very nice tuturial tank you very mutch, gsm tower do you no after unlock what is the USER CODE, and what is the SECURITY CODE. I think they change for the: USER CODE--- 12345 SECURITY CODE------ 0000 Ken you say to me if this is right, please, because i saw in information, after unlock, but i forgot and no iīm a bit confused. Tank you very mutch Best regards |
04-07-2006, 21:25 | #9 (permalink) |
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | @upa I think they are not changing,but after unlock with phone powered up you can see it in information tab for sure regards |
05-10-2006, 15:38 | #12 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 210830 Status: Offline Thanks Meter: 4 | This is the way i do all my Moto phones: conect cable to phone without batery connect battery conect TP now connect power(in some cases, d phone'll show blue light) Press search in smart moto flash rainbow pog found disconnect TP now press unlock via testpoint wait untill smartmoto shows unlocking ok... Ur phone is unlocked. Always worked for me. |
05-10-2006, 18:02 | #13 (permalink) |
Junior Member Join Date: Apr 2006
Member: 264747 Status: Offline Thanks Meter: 0 | Testpoint were? Can you tell me what's TP or testpoint? What do I have to do? I have a e770v and I understand the rest of the process but I miss this part. Can you help me? If you have some pics please send me to [email protected]. Thanks. |
05-11-2006, 08:53 | #14 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Pakistan < Karachi Age: 41
Member: 76456 Status: Offline Sonork: 100.1678368 Thanks Meter: 60 | - You must Disssemble the phone 2- Connect USB cable to phone (Not need to repair) 3- connect tesetpoint to ground 4- Connect phone battery 5- Press "Search" button in SmartMoto 6- SmartMoto should find "S Blank Neptune LTE" or "S Blank Paragon POG", or "S Blank Rainbow POG" 7- Disconnect test point 8- The phone is ready for theUnlock or flash/repair operations now. sucessfull i did 15 to 20 mobiles |
Please help with my unlock with my 3G | kenny8881 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-03-2009 15:20 |
HELP WITH E770v | touch_111387 | Smart-Clip | 2 | 04-23-2006 20:13 |
need help with c55 unlock?maybe freeman can help | sincere | Phone Unlocking Codes & Maps | 24 | 10-21-2003 16:55 |
Help with bad unlocked J6 | Permonik | Sony | 4 | 02-13-2002 19:53 |
Newbie needs help with A36 unlocking | winnerz | x1x to x45/x50 | 3 | 11-15-2001 21:47 |
