Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 02-27-2009, 21:53   #1 (permalink)
Member: 577377
Thanks Meter: 12
HElp me v3re keypad not working after unlock
I unlock a v3re but after unlock keypad not work i change the flex and isnot flex problem
Old 02-28-2009, 03:19   #2 (permalink)
Orange_Dominica's Avatar
Member: 88701
Thanks Meter: 381
Hi
Try and disconnect the switch-speaker flex..(located inside the LCD assembly) ..and post results
Good Luck.
smokin
Old 02-28-2009, 03:24   #3 (permalink)
Super Moderator
rmarconcini's Avatar
Member: 394257
Sonork: 100.1583308 temp.disabled
Thanks Meter: 917
Take a look around the TP area, search for somenthing broked.
Old 03-01-2009, 16:05   #4 (permalink)
Member: 577377
Thanks Meter: 12
Dont work I try this solution
Old 03-02-2009, 03:03   #5 (permalink)
Member: 88701
Thanks Meter: 381
Some other things to check......
When the phone powers on fully..the display will be illuminated and then the backlight will go off.
After the LCD backlight goes off...press for a short time the power on button and check to see that the backlight comes back on again..post results.
In checking the skems for V3RE... there are only 2 componants between the keypad flex and the controller...a filter and a protection array...see below.
You can remove VRBB1 and then check to see if keypad operation is back to normal
If you remove FL1401, be prepared to replace it, because keypad signals pass thru this filter and its in series with the controller.
,smokin
e50 keypad not working after unlock moustafatch Nokia Hardware & Hardware Repair 5 11-19-2008 11:08
e65 keypad not working after unlock scoicagsm Nokia Hardware & Hardware Repair 3 08-09-2008 20:05
V975 Keypad Not Working AFTER UNLOCK ashok_kumar459 Motorola P2k 6 05-20-2008 19:03
L6 keypad not working after unlocked please HELP!! san20176 Motorola P2k 8 11-20-2006 17:21
Page generated in 0.23009 seconds with 8 queries
