02-25-2008, 17:45 | #1 (permalink) |
Banned Join Date: Oct 2005 Location: www.cilianunlock.com
Member: 194420 Status: Offline Thanks Meter: 15 | HELP unlock W490 Switching to flash mode... OK Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 0.00 Boot prepare... failed whit Smart TP V1.0 Last edited by cilian; 02-25-2008 at 17:53. |
02-26-2008, 09:42 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ cilian, This error usually appears when TP needle or battery hook wasn't connected properly. Also, please tell us what power adapter you are using with the Smart-Clip and why the phone was connected in boot mode. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 02-26-2008 at 09:57. |
02-26-2008, 16:15 | #3 (permalink) |
Member: 194420 Status: Offline Thanks Meter: 15 | I am using the original adapter, alli this in boot mode because attempt already was like the 5! the TP and the current estan well, not that but to do to him! |
02-26-2008, 16:36 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ cilian, Recommended value for Smart-Clip power supply is 12V 750mA. Please check your power adapter, and run unlock procedure once again In case if some error appears, please post full log file here. Just don't forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-04-2008, 09:30 | #5 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 589869 Status: Offline Sonork: 100.1593501 Thanks Meter: 552 | //////////////////////////////////////////////////////////////////////// Last edited by GSM_Support; 04-04-2008 at 09:36. Reason: Contained serial number |
<< Problem while unlocking W490 Need help >> | Faisal_Computer | Smart-Clip | 2 | 11-02-2008 14:58 |
help unlock w490 not getting to unlock | taariqmajid | Smart-Clip | 10 | 08-08-2008 08:14 |
help about w490 white screen | CONCORDIA GSM | Smart-Clip | 2 | 02-07-2008 09:01 |
HELP unlock W490 | venomhotboy | Smart-Clip | 14 | 02-01-2008 15:18 |
help unlock w490 | chris2007 | Smart-Clip | 1 | 12-10-2007 08:29 |
