03-13-2008, 09:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: morocco Age: 45
Member: 286812 Status: Offline Thanks Meter: 22 | help unlock w510 problem Searching for phone... found Motorola Phone (W510-orange), getting test interface... OK Model W510-orange Firmware R452G_G_08.11.05R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901BF2B5D951DBE.bk_ Searching for phone... found Motorola Phone (W510-orange), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M30L0R8000T0, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 3555600****** IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE2 3555600******x (2).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901BF2B5D951DBE.bk_ Restore OK Unlocking phone... error 9B smart testpoint problem or.... |
03-14-2008, 10:06 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ usmartu, This error usually appears in case if the TP was held too long or some other PCB component was touched. Please ensure that the board is clean and repeat unlock procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-26-2008, 18:13 | #7 (permalink) |
Freak Poster Join Date: Oct 2005 Location: FREETOWN- SIERRA LEONE
Member: 194431 Status: Offline Thanks Meter: 22 | w490 unlocking problems Ive been trying for 3days now to finish this motorola w490 and no way uptil now can anyone help as the box went of after prepare and now when about to restart the process it just reads half way reading failed timed out io whilse the screen says CRITICAL ERROR can anyone help me end this saga sending boot....ok failed io timeout |
04-26-2008, 18:40 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | Quote:
04-26-2008, 21:09 | #9 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
some w510,w490 for me work only with TP A conected,some with TP A and B conected. Try see if box have enough power,use good usb cable(better to use original@ phone conector is clean and good soldered),battery for first stage is full charged,PC with good LPT port(better use branded PC),TP area is not damaged. Must work. | |
help unlock x70 probleme | abote didier | Infinity-Box | 1 | 02-02-2010 21:29 |
need help to unlock w510 | alarmtech | Rocker Dongle (By Legija) | 1 | 11-07-2008 16:17 |
Smart clip team help unlock v3re problem | dxm | Smart-Clip | 10 | 01-28-2008 13:34 |
problem unlocking w510 | trycktill | Smart-Clip | 7 | 01-08-2008 15:06 |
problem unlocking w510 | guicholili | Smart-Clip | 1 | 10-30-2007 19:18 |
