05-10-2007, 10:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | help v3i r47a after unlock by prepare phone now in bootmode only |
05-10-2007, 10:34 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ freakyass, If after unlock via Prepare cycle the handset stays in boot mode, then it was connected in boot mode or Prepare cycle wasn't made properly. Flash the phone with the same firmware version as it originally had or higher one and everything will be ok. P.S. Flash it with original platform flash file. If it was r47a, originally, you have to flash it with the same one. In other case the handset will stay in boot mode. And flash chip should be replaced to repair it. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-10-2007, 12:38 | #3 (permalink) | |
Member: 154522 Status: Offline Thanks Meter: 48 | Quote:
ps: do you have sonork id my id as freakyass.regards sir | |
05-10-2007, 12:42 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ freakyass, If original firmware version was r47a try to perform repair PDS and after that Full Flash the phone with R47A_G_08.D8.A1R. If that won't help try to flash it with *.pcf file (R47A_G_08.D9.75R). Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-10-2007, 17:42 | #5 (permalink) | |
05-11-2007, 02:06 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 49
Member: 81501 Status: Offline Thanks Meter: 41 | hello sir how did you solved your problem i have also here v3i unlock try different version but always go to bootmode can u share me files .pcf.................thanks im using smartclip scard but i cant make it...................... |
05-11-2007, 04:10 | #7 (permalink) |
Member: 81501 Status: Offline Thanks Meter: 41 | anybody want to help me?pls...........................i did all flash file coming from smartclip support site but same problem..........i dont have a .pcf format cause i cant download anymore from support site................. |
05-11-2007, 07:22 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ iolejoi, Please tell us what firmware version the handset originally had and with what flash files you have flashed it. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-17-2007, 22:55 | #9 (permalink) |
Insane Poster Join Date: Dec 2004 Age: 53
Member: 96346 Status: Offline Thanks Meter: 2 | I have a phone with the same problem ... my phone is V3i boot 0A.52 and the version is R479_G_08.b5.76R but after unlock the phone stays in boot mode ... some friends sugest to me that download the boot and I download the boot to 0A.30 ... please some body can help me ?? I can't fix it Thanks friends ... |
05-18-2007, 07:03 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ BLACKSABHAT, Try to make Repair PDS and after that Full Flash the phone with the same firmware version that the handset originally had. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-18-2007, 19:19 | #11 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | i recieve 1 V3i ****ed by other Guy Now i dont know its old versiobn because PDS repair was applied . Now Boot Loader shows version r47a .. I fullflash with the same version which phone shows version after repiar pds but it didnot work ... phone stays at Boot loader mode |
05-18-2007, 19:28 | #12 (permalink) | |
05-21-2007, 12:23 | #15 (permalink) |
Junior Member Join Date: Mar 2007
Member: 479918 Status: Offline Thanks Meter: 0 | hi . i had replaced the flash chip of v3i and now its dead . when i try to flash it the strang message appeared. flash data failed (48mb) flash data dosent suite phone memory. and its showen also when i try to repair pds. any help |
Nokia 2330c after unlock by MTBOX phone resetting !!! need help. | Nestor7 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 12-06-2009 21:27 |
plaese help me n96 after unlock by zulea soft | karim8 | Nokia Base Band 5 ( BB-5 ) | 7 | 07-08-2009 17:33 |
Help Help Configration Error After Unlock By Dream Box | aaneel | DreamBox | 3 | 08-25-2008 08:57 |
k618i cid 52 after unlock by KKClient phone need unlock cood | ciaoeuro | KULANKENDI Server | 3 | 12-12-2007 00:59 |
V3i Dead after unlock, and Critical error DE/CA now | desanclador | Motorola P2k | 7 | 11-30-2007 07:47 |
