03-11-2006, 03:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Brazil Age: 44
Member: 77651 Status: Offline Thanks Meter: 21 | How to fix the error 'Incomplete chip identification' ??? Tnx. |
03-11-2006, 08:32 | #2 (permalink) |
Junior Member Join Date: Dec 2004 Age: 49
Member: 98701 Status: Offline Thanks Meter: 0 | I had the same problem with a v551 i could never fix then i had the same problem with a v3i till a read in a post to use rsd lite 2.5 with the cable connected to the back of the computer and use a ******* flash and like a miracle i could fix the v3i ..but the v551 i could never make it work i guess sc need to work more on this . I ended up fixing with free tools instead the one's provided by sc. try rsd lite 2.5 and cable and let me know. |
03-11-2006, 10:07 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello kades, Please post a log file of unlock process, it would spread some light on your problem. P.S. Do not forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-11-2006, 13:39 | #4 (permalink) |
Member: 77651 Status: Offline Thanks Meter: 21 | Hi! Follows my log of today... because unfortunately I didn't save my operation log yesterday... Tnx. kadES Clip serial: XXXXXXXXX , version: 2.22, initializing... OK Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 353103006191386 Security area saved to "S Flash Neptune LTE 353103006191386 (9).pds" Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 353103006191386 Security area saved to "S Flash Neptune LTE 353103006191386 (10).pds" Incomplete chip identification, restore & write functions unavailable |
03-12-2006, 07:42 | #5 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Moldova Age: 41
Member: 204045 Status: Offline Thanks Meter: 7 | For me this problem was solved using test point! This was happened with V220 motorola. So i connected the test point and flashed it and now this phone is working 100%! Just try it! Best regards! |
03-12-2006, 08:04 | #6 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | Quote:
Reading flash id... Intel-0x0089 Flash ID messed up and do the test point. | |
how to fix this error? everytime i open mxkey this error appear! | jap_line | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 04-27-2010 13:23 |
how to fix the configuration error of k608i? | kamot37 | Cruiser Suite | 2 | 07-17-2008 05:38 |
Anyone know how to fix the " Insert Sim " problem on the SE K500i ? | Patrick | Sony Ericsson Hardware Repair | 3 | 07-01-2005 18:02 |
How To Fix The Cable To Fisio 355 ? I Need Help | sunrise gsm | Redbox | 17 | 01-27-2005 10:41 |
How to remove the T19X flash chip | jerrel | Motorola ODM | 0 | 08-25-2003 00:51 |
