02-21-2008, 13:27 | #3 (permalink) |
Insane Poster Join Date: Sep 2005 Age: 45
Member: 183834 Status: Offline Thanks Meter: 6 | the scout can erase the flash, but also flash failed, the error log attached, I will attach the smart-clip log then: Line: 579 ERROR: Flash failure: Phone[0000]: Error flashing subscriber unit. Device API Error: 0xE0030007 Address: 0xA00800D0 Command: ADDR (Error Code: e0030007), Detailed Error Details: Direction of the Error=1000, Command Value=200000, Code Group Number=1 File: D:\test_dev_usb\flash\code\flashdll\FlashHdlr.cpp Device ID: 0 |
02-21-2008, 13:53 | #5 (permalink) |
Member: 183834 Status: Offline Thanks Meter: 6 | original sw is: R27231_U_97.04.0DR, now the phone into the bootloader mode, the smart-moto log as following: SmartMoto 3.10 S-Card: xx Smart-Clip dongle, v 2.06, assigned Smart-Clip: xx Europe, initializing... OK Clip serial: xx, version: 4.06, initializing... OK Searching for phone... found SE Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F0 Boot prepare... failed Last edited by GSM_Support; 02-21-2008 at 16:08. |
02-21-2008, 14:52 | #6 (permalink) |
Banned Join Date: Jan 2008
Member: 688930 Status: Offline Thanks Meter: 0 | A couple of things you can do, use TP for V3xx or try to load a different boot-loader. Q. which one you using for prepare V3xx or V3xx untypical.... Last edited by GSM_Support; 02-21-2008 at 15:20. |
02-21-2008, 23:00 | #8 (permalink) | |
Banned Join Date: Aug 2004 Location: Gsm Unlockers Awareness Report
Member: 76978 Status: Offline Thanks Meter: 15 | Quote:
I got confused with V3x and V3xx to use test point on V3xx you need to pass the prepare cycle. The question on changing bootload that would answered with SC support. | |
02-22-2008, 10:22 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | If your V3xx has a boot version 05.F0 then i presume it's a prototype unit and is not possible to replace boot on it. Can you sell us that phone? If yes, please contact me in PM. Best Regards GSMServer team |
02-23-2008, 03:59 | #10 (permalink) | |
Member: 183834 Status: Offline Thanks Meter: 6 | Quote:
prepare failed | |
How to flash the life timer of nokia HPs to 0? | coldcar | Nokia Base Band 5 ( BB-5 ) | 2 | 02-20-2008 08:23 |
how to flash the new firmware to phone? | polychrome | Samsung Flashers, Software, Firmware. | 1 | 06-10-2007 22:35 |
TST, How to flash the I300? can we use the original USB Cable? | sim1 | TST Dongle | 5 | 01-21-2006 05:49 |
How to flash the gprs file to the phone using UFS? | hooi76 | UFS2 + UFS3-Tornadoflasher | 0 | 03-03-2005 02:35 |
How to flash the 83xx or 8855........ | johnnyvu2001 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-29-2002 22:56 |
