06-24-2013, 13:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | How to unlock E1000 need help i can enter to this public download please can someone give and how to unlock Remove RSA passed succesfully log overwritten so cant give log here SmartMoto 4.29 S-Card: 831347428 Smart-Clip dongle, v 3.10, assigned Smart-Clip: 236145849 Europe, initializing... OK Clip serial: 236145849, version: 5.03, initializing... OK Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Switching to flash mode... OK [S Flash Rainbow POG] Reading phone boot version... 6.31 load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Sending boot... OK Writing flash... OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 354756003695631 IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 354756003695631.mbk" Phone initialization... OK "Remove RSA" performed successfully, you may service and unlock the phone as usual Turning phone off... OK Connect phone to Smart-Clip before proceeding Connect phone to Smart-Clip before proceeding Connect phone to Smart-Clip before proceeding Connect phone to Smart-Clip before proceeding Connect phone to Smart-Clip before proceeding Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Switching to flash mode... OK [S Flash Rainbow POG] Reading phone boot version... 5.F1 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 354756003695631 IMEI OTP status: locked Security area saved to "PDS for Motorola E1000 354756003695631.mbk" TestPoint unlock not supported for this boot version Operation log saved to "C:\Documents and Settings\Администратор\Рабочий стол\SmartMoto log 24-06-2013.txt" Login request... OK Preparing... io timeout Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Zeroing special code...failed[07] Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Performing "Master Reset" operation... OK Performing "Master Clear" operation... OK Zeroing special code...failed[07] Zeroing special code...failed[07] Zeroing special code...failed[07] |
06-24-2013, 16:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 266 | Unlocking E1000, V1050, V975 (ver R245_xxx) (inc. boot 0.6.1.2) and others models with boot 0.6.3.1 Connect the handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC). Connect S-Card to PC USB port. Connect power supply to Smart-Clip and power on the handset. Launch SmartMoto. Choose "Smart-Clip USB port" in phone connection window. Press "Search". Software should perform the following steps: SmartMoto detects S-Card; SmartMoto detects Smart-Clip; SmartMoto detects the handset and reads all information. Log to bookmark "Unlock". Pickup correct model from the scrolling list. Press "Remove RSA". Phone goes into boot mode. Reserve copy of security area is created. Part of phone firmware is reflashed. Phone doesn't power on after that. SmartMoto will give the message requiring to take phone into boot mode by pressing keys combination: *,#, PWR ON (at this moment the phone has to be connected with USB cable) or by using Repair cable. Press "OK" button. Wait till the process finishes. The phone powers on and is ready to be unlocked by Smart-Clip using simple "press one button" method (Standard unlock procedure for P2K models). |
06-25-2013, 10:23 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ soctia, The phone powers on and is ready to be unlocked by Smart-Clip using simple "press one button" method (Standard unlock procedure for P2K models). Here is unlock procedure. Best Regards GSMServer team |
06-25-2013, 11:12 | #4 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | hello i cant unlock phone i press many times Unlock button nothing is changing no green and red color phone is going to flash mode please how to unlock phone SmartMoto 4.29 S-Card: 831347428 Smart-Clip dongle, v 3.10, assigned Smart-Clip: 236145849 Europe, initializing... OK Clip serial: 236145849, version: 5.03, initializing... OK Searching for phone... no phone found Searching for phone... found Motorola Phone (E1000), getting test interface... OK Model E1000 Firmware E1000_U_82.32.30I_H Zeroing special code...failed[07] Zeroing special code...failed[07] Zeroing special code...failed[07] Switching to flash mode... OK [S Flash Rainbow POG] Reading phone boot version... 5.F1 This phone does not need "Remove RSA" procedure, you may unlock it with Smart-Clip button Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK |
06-27-2013, 11:42 | #7 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | i am in trouble now with this phone i know where is unlock button is placed after some experiments phone is not powering on on lcd this error ERROR: 0xDAB i write E1000_BOOTLOADER_0.6.3.1.shx with RSD phone was working but after unlocking with P2K_Easy_Tool_v37 something go wrong i try to repair PDS but not succesfull how can i repair phone thanks SmartMoto 4.29 S-Card: 831347428 Smart-Clip dongle, v 3.10, assigned Smart-Clip: 236145849 Europe, initializing... OK Clip serial: 236145849, version: 5.03, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 354756003695631 IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 354756003695631 (2).mbk" Login request... OK Writing flash section 4 of 4... 100% (11.3 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK io timeout io timeout Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 io timeout io timeout |
06-27-2013, 12:44 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ Namangan, Perform Repair PDS operation and after that Full Flash the phone with the same firmware version like it originally had. Best Regards GSMServer team |
07-03-2013, 08:52 | #11 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | thanks to generous GSM-SERVER phone is working again bonus is taken fullflash downloaded pds reraired and flashed and of course phone is unlocked SmartMoto 4.29 S-Card: ---------- Smart-Clip dongle, v 3.10, assigned Smart-Clip: -------- Europe, initializing... OK Clip serial: ----, version: 5.03, initializing... OK Searching for phone... no phone found Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F1 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 354756003695631 IMEI OTP status: locked Security area saved to "PDS for S Flash Rainbow POG 354756003695631.mbk" Writing flash section 2 of 2... 100% (52.5 Kb/sec) Flash completed! |
The Following User Says Thank You to Namangan For This Useful Post: |
