06-06-2007, 10:04 | #1 (permalink) |
Freak Poster Join Date: May 2005
Member: 143322 Status: Offline Thanks Meter: 35 | I have Probleme..... i have probleme with my two of moto fones and same pb.....with e770 and v3x. When i connect the fones the folowing error displayed....i change the adopter to 12v but same pb.. SmartMoto 2.23 S-Card: 7xxxxxxxx Smart-Clip dongle, v 1.24, assigned Smart-Clip: xxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxxx, version: 3.17, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error This error is possible during phone turning on, you may try <Search> once again what is the pb... br. Faisal. OPal Mobiles. |
06-06-2007, 10:14 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ faisi, AT command error shows that the handset has User code enabled. You can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. If that will not help, than You should Full flash the handset using TP method. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-11-2007, 08:04 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mazmanx, Please explain in more details what problem you have. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-11-2007, 08:55 | #6 (permalink) |
Junior Member Join Date: Jan 2002 Location: naples Age: 50
Member: 9072 Status: Offline Thanks Meter: 24 | i same problem of connection whit phone try in this mode: put on central pin of battery a isolator and insert it (u have only + and - connect),the phone on must be whit message: invalid battery!; Last edited by anto73; 06-11-2007 at 14:51. |
06-11-2007, 12:26 | #10 (permalink) |
Member: 9072 Status: Offline Thanks Meter: 24 | which this: SmartMoto 2.23 S-Card: 9xxxxxx Smart-Clip dongle, v 1.24, assigned Smart-Clip: 5xxxxxx Europe, initializing... OK Clip serial: 5xxxxxxx, version: 3.17, initializing... OK Searching for phone... found Motorola Phone (V3i), getting test interface... clip communication failed Clip serial: 5xxxxxxx, version: 3.17, initializing... OK Searching for phone... found Motorola Phone (V3i), getting test interface... OK Model V3i Firmware R479_G_08.B4.34R Switching to flash mode... clip communication failed if i use battery solution not have this error more |
06-11-2007, 12:37 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ anto73, Take a look here, please. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-13-2007, 11:27 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | i have the same problem why by using prepare method u need to flash? why there is normal reset after unlock i.e. ubl via blank mode, also why gsmserver is not give the link for those who have the problem mfw full flasher until the other part upload file for us |
06-13-2007, 11:38 | #14 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | @ MGT SOFTWARE, Quote:
Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
06-13-2007, 11:39 | #15 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: InsideOut
Member: 333359 Status: Offline Thanks Meter: 91 | Quote:
""I have a Nokia 6280 having problem with startup - Please help me"" | rajeevpchandran | Nokia Hardware & Hardware Repair | 5 | 10-03-2008 06:41 |
Hi To All I Have Problem I Don't Play Video In 9210i I Have A Mm Converter But Can't | Shakeel Communication | Off Topic Zone | 2 | 07-30-2008 17:00 |
i have having problem to select flash file automatically from mt ; pls give ini file | monsterpassword | MT-BOX | 2 | 12-16-2007 18:55 |
i have a new mt bot i have problem | hassangmmm | MT-BOX | 3 | 11-23-2005 20:32 |
Still have problem with tia files? I have Tia.pacher! | lotfi17 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-14-2001 14:18 |
