03-31-2007, 00:30 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: GenSan City - Philippines Age: 44
Member: 57549 Status: Offline Thanks Meter: 33 | I Try to Unlock L2 but it wont work for me ... The following models can be served avoiding a TestPoint connection: Model Boot version C390 8.26 C975 6.36 E1 A.02, A.05 Å378i 8.25, 8.26 Å770 06.71, 06.81, 06.82, 06.83, 06.84 Å1070 06.71, 06.81, 06.82, 06.83, 06.84 L2 8.D0, 8.D5 L6 8.D0, 8.D5 L7 8.D0, A.20 U6 8.A1 V19x 8.A0, 8.D0, 8.D5 V1075 06.71, 06.81, 06.82, 06.83, 06.84 V1150 06.71, 06.81, 06.82, 06.83, 06.84 V235 8.E0 V360 8.A0, 8.D0 V3 8.28, 8.29 V3i A.30 V3r A.30 V3x 06.71, 06.81, 06.82, 06.83, 06.84 V557 8.B0 Please, be aware of the new unlock procedure: Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC). Connect S-Card to PC USB port. Connect power supply to Smart-Clip and power on the handset. Launch SmartMoto. Choose "Smart-Clip USB port" in phone connection window. Press "Search". The software should perform the following steps: SmartMoto detects S-Card; SmartMoto detects Smart-Clip; SmartMoto detects the handset and reads all phone information. Log to bookmark "Prepare". Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list. For unlock purposes, please make sure that "Unlock automatically" option is marked. Press "Prepare" button. The prepare cycle starts. SmartMoto creates a Temporary Backup File* from the handset firmware. For some models, SmartMoto will popup the following instruction to be performed: Remove phone’s battery; Insert battery back; Press power ON; Press ok in SmartMoto; The prepare cycle will continue. At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein Disconnect cable from the phone; Remove phone’s battery; Connect cable to the phone; Insert phone's battery; Press "Power on" key on the phone. Phone's LCD remains blank; Press OK in SmartMoto. The handset should be detected by SmartMoto as "S Blank..." with boot 2.00 (3.00). SmartMoto restores the temporary backup file If the option "Unlock automatically" was marked – the handset becomes unlocked. If the option was not selected then the handset can be served for Flash, Repair PDS, Unlock or Backup purposes. * Temporary Backup File is created by SmartMoto in work purposes and will be automatically erased from the Hard Drive as soon as unlock process is completed. If the handset was connected to SmartMoto, in boot mode the temporary backup file will not be created. In this case, after Prepare process is completed, the handset must be flashed with flash file and user data will be erased from the memory NOTE: If there was any mistakes made during unlock process, and the handset is in "MEM_MAP Blank" mode, then "Prepare" process has to be repeated and the handset has to be flashed with reflash or full_flash file. At the stage 11, handset screen might display a "Critical error" message. Please, don’t be worried and strictly follow the instructions of SmartMoto. after doing this .. My phone only start in BOOTLOAD ... I flash it with "R3511_G_0A.52.31R_D_JPJAVA_G_0A_L2_01_06_04R_GSIU L2MCL01NA115_1FF.pcf" firmware phone ok but not unlock ... please tell me any procedure to unlock this phone ... Thanks in Advance .. Regards, JammerOne Philippines |
03-31-2007, 05:04 | #2 (permalink) |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | You may try to unlock it using the prepare phone option. Dont forget to check => unlock automatically after prepare. Or else during the prepare cycle, when it says it needs to flash firmware, flash it with full flash(mfw) the same version as that in your phone, then unlock again. No testpoint needed. |
03-31-2007, 07:57 | #3 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
03-31-2007, 08:51 | #4 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 54
Member: 320105 Status: Offline Thanks Meter: 18 | i successfully unlock L2 boot 8.D0 with prepare cycle here is log Searching for phone... found Motorola Phone (L2), getting test interface... OK Model L2 Firmware R3511_G_0A.52.31R_D Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Sending boot... OK Performing backup to temporary file Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F924091A05C0B8A7.bk_ Backup OK Erasing flash memory error 80 Searching for phone... found Motorola Phone (L2), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... ST - M30L0R8000B0 Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 359818001997297 Security area saved to "PDS for S Blank Neptune LTE 359818001997297.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F924091A05C0B8A7.bk_ Restore OK Unlocking phone... OK |
try to unlock nokia 2630s it says sl3 info and dont unlock | observer123 | Universalbox | 3 | 07-23-2009 12:31 |
Try to unlock S500i but... | SaifiChanda | Trident/AGERE Platform | 0 | 04-22-2008 14:36 |
try to unlock e616 but Unknown Device | chris2007 | NEC | 5 | 06-14-2007 17:01 |
Dont Unlock Wth Cruiser!it Wont Work | borndevils81 | Sony Ericsson | 3 | 06-01-2007 02:24 |
I try to unlock E105 but the phone lock is back | faizzoll | Trident/AGERE Platform | 0 | 09-28-2004 02:54 |
