Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 06-01-2012, 10:39   #1 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
K1 flashing error
I have Moto K1 with following firmware inside.,
R4527_G.08.02.2E1_GNPO12_RF
08A0
Problem is i don't have bluetooth option in the menu.So i planning to flash the phone.when i try to flash phone get white screen in boot mode and flashing get error.but phone no have problem.
When i make boot in manual only comes white screen.
Note :
phone is brand new and i have qty of phone in same condition
Hope get Answer from supporter
Old 06-01-2012, 10:50   #2 (permalink)
GSM_Support's Avatar
Member: 121052
@ afrar,
Post here log file from the flashing operation, it would spread some light at your issue.
Don't forget to hide your serial numbers.
Best Regards
GSMServer team
Old 06-01-2012, 11:10   #3 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
I flashing with scout., Do you need scout log ?
Old 06-01-2012, 11:58   #4 (permalink)
Member: 121052
@ afrar,
Yes, post here log file.
Best Regards
GSMServer team
Old 06-01-2012, 12:36   #5 (permalink)
mcandre's Avatar
Member: 239548
What flash file have you flashed?
Also post how had the phone been detected before you flashed it?
Old 06-01-2012, 14:00   #6 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
Here i attach pic pls check it.,
ImageShack Album - 2 images
Old 06-01-2012, 14:13   #7 (permalink)
Member: 121052
@ afrar,
What firmware version are you trying to flash the phone with?
Best Regards
GSMServer team
Old 06-01-2012, 15:16   #8 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
R4527_G_08.22.03R_PDS012_LP0039_DRM0101_VSTG_30C_0 70809_JPJAVA_G_08_R4527_06_00_1ER_GSTCNRYORACH0C4_ 1FF_Orange_Switzerland
Old 06-02-2012, 08:47   #9 (permalink)
Member: 121052
@ afrar,
First of all update your SCout flasher to the latest version (v 2.01), after that download same firmware version like the set has and run flashing operation once again.
If some error appears, save log file and post it here.
Best Regards
GSMServer team
Old 06-04-2012, 18:13   #10 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
Same Flash file not available in support.,
Old 06-05-2012, 07:40   #11 (permalink)
mcandre's Avatar
Member: 239548
Your phone's firmware version hasn't been detected properly.
There are several possible reasons of that. Most possible reason is that something is wrong with PDS zone of the phone.
That's the reason why Scout doesn't allow you to flash the phone.
Old 06-05-2012, 15:26   #12 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
So what's the solution for that. As i told in the beginning i have quantity of phones in same problem
Old 06-05-2012, 15:47   #13 (permalink)
Member: 121052
@ afrar,
Try to perform following operation:
  • Perform Repair PDS operation using SmartMoto software
  • Flash the phone with the *.mfw flash file.
Please note that *.mfw flash files are meant to be used by the SmartMoto software.
According to the information you have provided K1 handset you have has boot version 8.A0. This Boot version is supported by SmartMoto via Prepare cycle.
By following this link you can find detailed manual on the Prepare Cycle operation.
Best Regards
GSMServer team
Old 06-07-2012, 01:07   #14 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
I try to repair PDS starts good at the end i got load error
Phone still good no any problem
If you want i connect for you team viewer you want do some test ?
Otherwise an send you 1 phone also .,
Thx a lot.,
Old 06-07-2012, 07:06   #15 (permalink)
Member: 121052
@ afrar,
Post here log file from the Repair PDS operation, without serial numbers.
Also, you can contact me via any messenger.
Best Regards
GSMServer team
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-28-1999 15:57
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.34797 seconds with 11 queries
