01-13-2008, 17:31 | #1 (permalink) |
Junior Member Join Date: Jun 2005
Member: 150831 Status: Offline Thanks Meter: 0 | K1 and Ubl TP problem |
01-14-2008, 07:51 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ adrian18w, Try to connect the handset via TP, perform Repair PDS procedure and after that Full Flash the phone with the same firmware version like it originally had or higher one. TP pictures can be found at boot-loader.com in Public Downloads section. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-14-2008, 14:56 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ adrian18w, Connect the handset via standard TP, not Easy TP. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-15-2008, 09:16 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ adrian18w, You don't need any special cable to perform standard TP procedure. Description of the TestPoint procedure: • Disassemble the phone • Connect the phone to PC via Smart-Clip, using standard cable(Not repair one), and launch SmartMoto • Connect Testpoint to ground (Connect one end of the cable to TP, and the other to any metal shield(ground)) • Connect Phone Battery • Press Search button in SmartMoto • SmartMoto should detect "S Blank..." • Disconnect Testpoint • After that the phone ready for unlock/repair operaion Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
ubl tp with smart clip | fidmdoe | Smart-Clip | 0 | 08-09-2009 08:43 |
v3r unlock via ubl and via tp good mr manole. | kikikokoki | Ultima Box Light | 0 | 04-08-2009 07:40 |
may unlock v3x via tp and ubl | kikikokoki | Ultima Box Light | 0 | 12-20-2008 09:32 |
Repairing IMEI on K1 and Z3 using UBL | paffka | Motorola P2k | 0 | 06-20-2007 13:01 |
only 40 seconds !!! boot 0A.52 with UBL and Magic TP, watch the movie | Raskal | Ultima Box Light | 0 | 01-20-2007 16:31 |
