Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 12-06-2006, 21:39   #1 (permalink)
Crazy Poster
Member: 81133
k1 unlock problem
right im having problems unlocking the k1, rather than go into "s blank SmartMoto 2.00
Dongle: 2xxxxxxxx Smart-Clip dongle, v 1.00, assigned clip: 60xxxxxxx Europe, OK
Clip serial: 6xxxxxxxx, version: 3.00, initializing... OK
Searching for phone... found Motorola Phone (K1), getting test interface... OK
Model K1
Firmware R4527_G_08.22.07R
Switching to flash mode... reconnect error
Check if the phone battery charge is OK
im using the testpoint box fully charged, i also tried with the nokia charger connected. what am i doing wrong? digits changed for security purposes.
i got it this time but only with the fone battery connected. left the tp box out of it. now im getting this message.
SmartMoto 2.00
Dongle: 2xxxxxxxx Smart-Clip dongle, v 1.00, assigned clip: 6xxxxxxxx Europe, OK
Model K1
Switching to flash mode... OK [S Flash Neptune LTE2]
Reading phone boot version... A.B2
io timeout
regards
Old 12-06-2006, 21:45   #2 (permalink)
eko
eko's Avatar
Member: 30098
Tp problem..............
Old 12-30-2006, 18:41   #3 (permalink)
Member: 194595
Try connecting the testpoint first and then the battery to the phone, then open up Smartmoto and press search.
Old 12-30-2006, 20:36   #4 (permalink)
gwaai's Avatar
Member: 49581
if ur TP is correctly performed, u will find BLANK LTE2 phone instead of K1
Old 12-30-2006, 21:35   #5 (permalink)
ikrash's Avatar
Member: 352041
bro ....i think the problem of ur timeing to put ur tp,when u pick the tp at the right time it will work normally.....its my own idea coz i also have faced such problem......ok...............ikrash
Old 12-30-2006, 23:59   #6 (permalink)
emwugsm's Avatar
Member: 88545
Just use an external power supply in stead of battery.
1. Connect TP to the ground
2. Switch power On in the power-supply
3. Press [Search] in Smart-Moto.
Here is a scheme of a simple power-supply adaptor from USB port:
Old 12-30-2006, 23:59   #7 (permalink)
Member: 264055
I had the same problem. If your using the fun fone shop testpoint box take the aligator clamp what is meant for extra ground and connect it to the ground.
k1 unlock problem nadirghazi Smart-Clip 3 08-08-2008 12:07
K1 Unlocking Problem !!! albarka network Smart-Clip 1 02-23-2008 10:24
Problem K1 Unlocking ian20essex Ultima Box Light 2 01-02-2008 13:19
k1/s unlocking problem sukhdeep Smart-Clip 1 01-02-2008 09:14
moto k1 unlocking problem legendmani Motorola Hardware Repair Section 2 04-26-2007 08:41
Page generated in 0.27197 seconds with 12 queries
