Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 05-12-2006, 18:24   #1 (permalink)
nabildeco@yahoo's Avatar
Member: 189532
Thanks Meter: 28
L6 dead after unlock ...help !
i unlocked motorola L6 as normaly ....of course with good test point ... smartmoto geft me : unlock......OK
but device don't start ...and also don't accept charge, means L6 is dead !!!!!!!!!!!!!!!
I tried to flash it ...but doesn't accept ....
The Following User Says Thank You to nabildeco@yahoo For This Useful Post:
Old 05-13-2006, 09:53   #2 (permalink)
Member: 189532
Thanks Meter: 28
by the way
i tried today another time ..... i succeded to read packup phone flash ....but always can't reflash it !!!!!!!!!!!!!!!!!!!!!!!!!!!!
anyone have idea for that ??????????
Old 05-13-2006, 11:57   #3 (permalink)
Member: 123140
Thanks Meter: 5
L6 Unlocking-interface not found
First time to use Smartmoto and i'm having this problem see log below:
SmartMoto 1.19
Clip serial: xxxxxxx version: 2.24, initializing... OK
Searching for phone... found S Blank Neptune LTE, getting test interface... interface not foundSwitching to flash mode... OK
what is the problem for interface not found "getting test interface... interface not found" or its normal i should proccede to unlock via test point
Thanks
Old 05-13-2006, 13:24   #4 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
SmartMoto 1.19
Thanks
it is the normal way.
make TP and PDS repair and then flash a fullflash into the phone.
best regards
The Following User Says Thank You to ottyone For This Useful Post:
Old 05-13-2006, 14:24   #5 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
when u removed metal sheild for test piont make sure that u have not left any metal splinters around test point area,they will cause short and mash up fone.so check very carefully with microscope then clean and remove all metal splinters..all will be ok....
The Following User Says Thank You to coolmax For This Useful Post:
Old 05-13-2006, 14:42   #6 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
No remove of the shield need -- lock here
--> http://forum.gsmhosting.com/vbb/show...8&postcount=24
best regards
Old 05-15-2006, 00:15   #7 (permalink)
dipu's Avatar
Member: 177730
Thanks Meter: 11
use a drill mechine for testpoint DO NOT remove metal shield, that would destroy your PCB for sure. reagrads
Old 05-15-2006, 07:23   #8 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
@dipu
the genuine professionals do not REMOVE oder DRILL into the shield
and mach your eyes up and follows that link, a contribution over yours.
best regards
Old 05-16-2006, 10:36   #9 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
Originally Posted by ottyone
@dipu
best regards
thanx for the link...but your method iz not possible to make test point on diffent models i.e C975,V3i,U6 etc..so how would you as a
"genuine professional" overcome this problem without removing metal sheild?plz explain.
Old 05-16-2006, 11:06   #10 (permalink)
ottyone's Avatar
Member: 35205
Thanks Meter: 14
Hm - this threat called
" L6 dead after unlock ...Help! "
and 4 the TP on L6 u dont need drill oder remove shield.
you do´nt belive it, but it is.
Help L6 Dead After Unlock jamohaki Ultima Box Light 16 04-28-2007 17:16
L6 Dead after Unlocking with Smart Moto " PHONE CODE SIG ERROR " Aamir_Zia Smart-Clip 53 06-13-2006 19:27
L6 dead after unlock with P2K opo Motorola P2K (USB-Smart) 1 05-03-2006 10:32
L6 DEAD after unlocking....... koa Smart-Clip 1 03-15-2006 14:49
L6 dead after Unlock Ran Smart-Clip 0 01-05-2006 01:58
Page generated in 0.17956 seconds with 9 queries
