12-11-2008, 13:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | L7 flashing problem SmartMoto 3.20 S-Card: ******** Smart-Clip dongle, v 2.10, assigned Smart-Clip: ****** Europe, initializing... OK Clip serial: ************* version: 4.08, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 REPAIR PDS ::::: >>> Reading flash id... 0x90 - 0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 620C3FF23F1E679 IMEI OTP status: locked Error: "Repair PDS" unavailable due to incomplete chip identification WHEN PREPARE PHONE ::::: >>> Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Boot version 0x300 is not supported for model 'L7' WHEN FLASH ::: >>> Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... 0x90 - 0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 620C3FF23F1E679 IMEI OTP status: locked Incomplete chip identification, restore & write functions unavailable need a help how to recover my mobile also try with Scout Incompatible superfile for Subscriber Unit state. The superfile selected is for reflash. Please use a rom superfile. Flash failed Thanks in Add. |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
12-11-2008, 14:07 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ kalpeshoza, "Incomplete chip identification" means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following 2 Users Say Thank You to Mr.Tinkertrain For This Useful Post: |
12-11-2008, 14:23 | #3 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | Thanks Mr.Tinkertrain but when i receive phone only key paid light blink i try with + # power on but not see the s/w version (not in boot mode) and yes fresh PCB , Tp is also ok ,why Hardware IMEI: 620C3FF23F1E679 ? i try with Restore IMEI but not work |
12-11-2008, 14:35 | #4 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | @ kalpeshoza, Quote:
Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
01-20-2010, 16:58 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | ..hello.. ..motorola L7..come to me completly dead.... ..repait PDS ok..full flash ok..unlock ok...but phone still dead.. anybody have an idea what can be ??? |
01-21-2010, 08:14 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ stefani, Please provide us with more detailed information. Do you know what had happened to the set so it goes to such state? What original firmware version the handset originally had? Please show us log file from the flashing/Repair PDS procedure, don't forget to hide your serial numbers. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
01-21-2010, 11:14 | #10 (permalink) | |
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
i don't know what happend ..and what firmwere was before... Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 357258001224339 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 357258001224339 (1).mbk" Login request... OK Writing flash section 2 of 2... 100% (22.9 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (11.5 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 7 of 7... 100% (43.4 Kb/sec) Flash completed! Unlocking phone... OK L7_R4513_G_08.B7.DCR_RB_lp002C_SE5748AXXW610A_flas h_flex.mfw Last edited by stefani; 01-21-2010 at 11:22. | |
01-21-2010, 11:25 | #11 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ stefani, Quote:
Best Regards GSMServer team | |
01-21-2010, 11:47 | #12 (permalink) | |
..this flash i use : L7_R4513_G_08.B7.DCR_RB_lp002C_SE5748AXXW610A_flas h_flex.mfw | |
01-21-2010, 11:52 | #13 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ stefani, As original firmware version isn't known, it's quite hard to suggest anything. Try to flash the phone with the R4513_G_08.B7.E0R_RB Full Flash file and post results here. Best Regards GSMServer team |
01-21-2010, 13:17 | #14 (permalink) | |
Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 357258001224339 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 357258001224339 (2).mbk" Login request... OK Writing flash section 2 of 2... 100% (23.4 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (12.9 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (50.5 Kb/sec) Flash completed! | |
01-21-2010, 13:25 | #15 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ stefani, What is displayed at the screen of the phone when you try to power it on? Best Regards GSMServer team Last edited by GSM_Support; 01-21-2010 at 14:03. |
L7 flashing problem | X-TRA | Smart-Clip | 3 | 01-18-2010 07:01 |
moto l7 flash problem | burraq | Smart-Clip | 10 | 04-08-2008 11:42 |
L7 flash problem | Spax | Smart-Clip | 17 | 12-27-2007 11:09 |
L7 flash problem | skd_123 | Motorola Hardware Repair | 0 | 12-05-2007 10:07 |
l7 flashing problem | sonetek | Smart-Clip | 1 | 08-10-2007 07:47 |
