Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 04-07-2006, 17:15   #1 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
moto a1000 black not start after smart-clip
motorola a1000 black after tp and smart-clip (procedure all done),show only motorola on display and shut down after 5 seconds.
batt. is ok.
any help?
tnks to all.
Old 04-07-2006, 17:22   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
here is tutorial
http://machman.gotdns.com/index.php
i only flash with pst
and result my a1000 is back to normal
Old 04-07-2006, 17:31   #3 (permalink)
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,715
Lightbulb
batt. is ok.
any help?
tnks to all.
You have damaged the TP resistor,Try to solder another resistor or just short both points of resistor.
Old 04-08-2006, 09:19   #4 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
all ok,tnks friend......u know the correct value of resistor? 33 ohm like v3x?
Old 04-08-2006, 14:07   #5 (permalink)
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,715
Lightbulb
No i don't have any idea but you can check the value from other phone if u have one.
Old 04-26-2006, 06:08   #6 (permalink)
Member: 126771
Thanks Meter: 20
sir pls send me motorola a1000 flash file version 01.02.011. can iflash phone other version pls tell me . and how can i flash tellme .thanks
Old 04-29-2006, 17:29   #7 (permalink)
Registered User
zakirn's Avatar
Member: 7457
Thanks Meter: 21
yes need this solution too. version 01.02011.
Old 05-16-2006, 01:13   #8 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
SC can unlock A1000 01.02.11 without problem
u can revive it with this full flash
REL_54.07.00_A1000_U_34.30.01P_000_1FF.rar
or with this
REL_51.95.00_A1000_Generic_modified_full.rar
download here
www.planetmobile.it
Old 05-23-2006, 19:50   #9 (permalink)
Ashwani Gaur's Avatar
Member: 2822
Thanks Meter: 152
or with this
download here
www.planetmobile.it
___________________________________________
Hi
Today I killed ome A1000- 01.02.11 WHILE FLASHING WITH pst.
I flashed this file:-
REL_54.07.11_A1000_Generic_small_PL_No_Mem_Card.sh x
First time it was FAIL
Second time it was Success but only AP flash
(BP was not done i dont know reasons and on Phone Screen only AP WILL BE FLASHED NO BP DRIVER FOUND somthing message was there.)
After Success Flashing PHONE was not alive
(with force boot cable it was going into Flash mode)
so I tried another time thime time Flashing FAIL and Phone DEAD.
Cannot go into Flash MOde even with FBcable.
Here is ERRRRRERRR LOG:=
ERROR: Interface AP-FS: Error Flashing Subscriber Unit Error 0xE0030008
while sending address 0x5F30000.
Can you help me to REVIVE this SMALL BRICK
WBR
ashwani gaur
Old 08-17-2006, 12:21   #10 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Hi m8s
Having Problem with A1000.
Just hava Look
After that i Flashed it with A1000_Lite_54.08.09_CG11_CG14_ENG.shx
But After Successfull Flashing No Luck.
Any IDEA?
Best Regards.
Old 08-18-2006, 09:45   #11 (permalink)
davesmobiles's Avatar
Member: 92178
Thanks Meter: 14
Good Reply's, but anybody who hasn't found the answer here regarding A1000's are better off giving http://machman.gotdns.com/index.php a Look.
Your'l find page after page of the above problems with alot of people getting there A1000's up and running again. Also all the needed Flashfiles are in there download area for Free. The tutorials are very good aswell.
If you need the hard to get hold of RSDlite or PST you can find them here http://www.eastcoastpc.co.uk just click the link to the forums and look in the motorola section, under most wanted flashes & Files.
Hope that helps someone
Old 08-18-2006, 12:34   #12 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Oh Yes Thanks Brother for ur Reply.
My Moto is back to life with help of great page.
and this is also fabulous.
www.planetmobile.it
Best Regards.
Old 11-17-2006, 22:28   #13 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 22
wow. hi guys
my a1000 is repaired, after unlock my phone is dead, i'm use all repair solution. for me work.
thanks to all
or with this
download here
www.planetmobile.it
Old 11-18-2006, 19:23   #14 (permalink)
vilibrook's Avatar
Member: 35101
Thanks Meter: 12
or with this
download here
www.planetmobile.it
THIS IS THE BEST SOLUTION TO REPAIR THIS SMARTPHONE.
ALSO USE RSD LITE 2.7
Old 03-26-2007, 20:27   #15 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 82
Hi my A1000 was dead after unlock with SC using TP.
Now it only can turn light and power down after 5 sec.
I have been flashing 3 files:
REL_51.92.20_A1000_U_34.16.01P_SE5066AXXF4_000_1FF .shx
REL_51.92.24_A1000_U_34.16.01P_SE5065AE7W6_000_1FF .shx
REL_54.07.00_A1000_U_34.30.01P_SE5056AE8W8_000_1FF .shx
with PST and during flashing procedure I've got this error:
22:25:01, March 26, 2007
Line: 3922
ERROR: Interface BP: Error Erasing Subscriber Unit. Error 0xE0020081
File: Y:\test_dev_usb\flash\code\flashdll\PST_FP_FlashTh read.cpp
What does it error mean? Please any hepl!
Problem i have faced was the damaged resistor during TP procedure. After shorted it all ok.
A1000 how to unlock in SMART CLIP here: bronce Smart-Clip 0 04-22-2008 05:01
After Smart Clip update its just not working drancill Smart-Clip 2 12-29-2007 00:44
v3x not charge battery after smart-clip nykocam Smart-Clip 2 04-12-2006 14:20
Moto A1000 hang on start up i_am_rocky Smart-Clip 3 12-17-2005 09:20
Page generated in 0.28814 seconds with 9 queries
