11-16-2007, 07:25 | #1 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | motorola C168i unlock failed here is screen shots SmartMoto 2.44 S-Card: xxxxxxx Smart-Clip dongle, v 1.52, assigned Smart-Clip: xxxxxxxxEurope, initializing... OK Waiting for the phone to power on....failed Waiting for the phone to power on....failed Clip serial: xxxxxx, version: 3.25, initializing... OK Waiting for the phone to power on...failed here is my procedure Quote:
i use t191 com cable. but i got always failed any news about this model.. | |
11-16-2007, 07:32 | #2 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: ROMANIA/Alexandria Age: 44
Member: 230301 Status: Offline Sonork: 100.106864 Thanks Meter: 1,434 | Quote:
Man use data cable select right com from data cable or universal box and all is ok.In case check the conection. | |
11-16-2007, 16:32 | #3 (permalink) |
No Life Poster Join Date: May 2004 Location: Coimbatore, India Age: 41
Member: 65535 Status: Offline Thanks Meter: 451 | i too same symptom any solution for this? am using correct cable and correct com port but still same pls anyone have a good solution Last edited by GSM_Support; 11-17-2007 at 10:41. |
11-17-2007, 10:44 | #4 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | When SmartMoto informs Quote:
Best Regards GSMServer team | |
11-18-2007, 10:22 | #6 (permalink) | |
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
yes sir.. i try it many time after smart-clip says Waiting for the phone to power on i press the power on but no effect.. | |
11-18-2007, 10:23 | #7 (permalink) | |
Yes my cable working fine... couse is it tested many time for other phone... | |
11-18-2007, 10:24 | #8 (permalink) | |
11-19-2007, 08:22 | #9 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | The unlock of C168/C168i is checked again. There are no bugs in software. I am sure that there is a trouble with phone connection (the cable doesn't work, drivers are not installed properly, proper COM port is not selected). Best Regards GSMServer team |
11-19-2007, 09:51 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | We have tested Unlock of C168/168i with original cable with virtual COM port emulator and it 100% worked. More likely your hardware COM port doesn't support required speed. Please use with Smart-Clip original accessories only. Best Regards GSMServer team |
11-22-2007, 23:46 | #13 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Yes...there is a problem unlocking new ATT C168i . After SC fails to detect power_on ,I used the program MST and got good reads of IMEI and SW version so this is NOT a cable problem. Maybe the new ATT c168i needs a diffrent loader? |
11-29-2007, 09:46 | #15 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ badillo, Please tell us what firmware version that C168 has. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
unlock failed sfr 112??? | gurbuz | FuriousGold | 2 | 03-30-2010 10:22 |
help..can motorola c168i unlock by codes..? | sigma xi | Motorola ODM | 2 | 10-28-2008 05:38 |
Please help Unlock Motorola c168i AT&T USA | Krapthing | Phone Unlocking Codes & Maps | 1 | 06-21-2008 15:34 |
help with unlocking motorola c168i | drlovethefirst | Infinity-Box | 20 | 10-30-2007 15:46 |
